Kenmore 53642 / 53644 Side by Side Refrigerator Logo
Posted on Jan 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore fridge stopped cooling
My fridge stopped cooling and then the freezer stopped freezing a few days later.  Then I unplugged it and cleaned all the coils underneath and turned it back on after 8 hours.  Then it worked again for about 5 days and stopped cooling again, then the freezer stopped freezing 2 days later.  Now I turned it off today for about 8 hours again and it started to cool and freeze again just like last time.  The relay looks to be in good shape.  What could this be?
  • heitmanncmi Jan 13, 2009
    I'll try it and let you know what happens.  Thanks!
  • Anonymous Mar 18, 2014
    Fridge has had leakage of water from under veg. drawers for several years. Recently stopped freezing and cooling. I emptied everything and huge amount of water drained over 2 days from underneath and from inside fridge. Restarted motor and freezer worked fine. Fridge is cool but not cold enough. Should I just give up and start shopping?
Anonymous
Level 3:
  • Master 700 Answers
  • Posted on Jan 12, 2009
Anonymous
Master
Level 3:
Answers
700
Questions
Helped
306906
Points
1781
Sounds like its freezing up on you. check the drain outlet and make sure that its clear. also i would replace the defrost timer on this unit because its suppose to bring on the heaterfs to melyt the ice so thaat yoiu don't have to. they are around 30 mdollars at the appliancew repair store and all you need is the model number and serial number for the uit. after you get it it's either on the very top of the refrigerator section or in the very back. It has 4 wires going to it. good luck.
Kenmore trio freezer and fridge not cooling. we used to have problems where the fridge would be perfect but the freezer was always too cold, sometimes causing the freezer door to freeze shut. but we had a...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
2helpful
Freezer won't stay consistently cold
replace temp sensors in fridge and freezer (easier to do together) should work fine...
1helpful
2answers
Refrigerator not cool, freezer ok
Either the freezer continues to freeze up (most likely due to low refrigerant, due to a leak), or there is an obstruction between the freezer and the refrigerator (refrigerators get their cooling from the freezer).
Given that it works after you defrost it, I'm going with low gas. Call a professional to see if the leak can be fixed. If the unit is more than 10 years old, just get a new one.
1helpful
2answers
Fridge wasn't cooling but freezer was working, now both aren't
Hi,Your husband did good job, after cleaning and vacuuming, did freezer (bottom) have excessive ice?, if there's excessive ice in bottom, after cleaning, you have a defrost problem, but if there're no ice in freezer after cleaning, you got freon (gas leak) , there's a condensate loop, that passes through ref. body, from compressor that naturally develop, freon leak after few years, by rusting, normally it can be by- pass. vacuum and refill with freon, if there's no freezing, but compressor running, you'll need a mechanic, you got a freon leak. good luck.
1helpful
Fridge and freezer are not cooling well
hi.
If the evaporator fan isn't working, that's probably the problem. Test here>http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
thank u
rate me!!
The freezer on our kenmore fridge keeps freezing up and then the fridge doesn't cool. It's a bottom freezer style. We have to unplug it and let it unfreeze in order to get it working properly again but it...
defrost problem, check defrost thermostat on evap coil by removing the back panel in freezer for continuity, if open, replace. check heater in the same fasion, if open, replace. if both are ok, replace defrost timer, or adaptive defrost control.
2answers
Refrigerator compartment not cooling
If you are sure the fan in the freezer is running and you don't feel any air flow out of the top middle vent inside the fridge section, then the damper motor must be bad. The damper motor is behind that vent cover inside the fridge section.
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
