Question about Solar Noma 7 Day, 6 Event Outdoor Timer - Easy To Use +warr
Hi, I have a Noma moonrays 88 watt timer with two buttons on the front and a display from 0 to 9. the top button seems to be a manual/auto switch and the bottom one has a clock symbol, but i can't
  • 1 more comment
  • Chris Gill Dec 09, 2012
    unfortunately my timer has a display that only goes from 0 to 9, definitely not 12 as the picture for the other one has. there is no visible model number, and no instructions and the woods timer site doesn't cover this particular one. i can get the lights to come on with the manual button, but a timer would be nice, or even how to tell it to go on when it gets dark etc.
  • Gene Haynes Dec 09, 2012
    Work with me. I am a timer expert. After many attemps, I cannot find a manual for Moonrays. OPEN the link I sent. Image shows 8 in the display, not 12. Open the link and read BOTH possible manuals for the moonrays. This is a dawn-dusk timer: The 8 means: Automatic ON at dusk and OFF 8 hours later. Read the possible manuals and say which one matches your product.
    If timer override button works to keep lights ON, then plug power pack into cheap outdoor wall timer like Woods 50012 at amazon:http://www.amazon.com/Woods-50012-Outdoo...
  • Solar Master
  • 5,353 Answers
1) Copy following link for to identify timer, and possible instructions
http://waterheatertimer.org/Woods-timers-and-manuals.html#Moonray
2) Add comment and say what you discover about setting timer
3) Look on timer, and sometimes the instructions are printed on paper label
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Dec 09, 2012
SOURCE:
Instruction manual for 052-8815-0 Wish to set timer for use 4 hours a day
Do you mean the Noma Digital Photocell Outdoor Lighting timer? If so, the manual is available at Canadian Tire on the product page: http://www.canadiantire.ca/en/pdp/noma-outdoor-lighting-timer-1-outlet-0528815p.html . Look on the right hand side under the Additional Info header below the other items viewed by those looking at the timer. The direct link to the manual is currently http://www.canadiantire.ca/content/dam/canadian-tire/manuals/0528815_ENFR.pdf .
If you want the timer to come on at dusk and stay on for 4 hours, press the Program button repeatedly until 4 shows in the LCD display window.
I hope this helps.
Nov 27, 2016 | Hardware & Accessories
Noma 052-8873-0 I program my timer, it run fine
Timer has worn out? Defective timer. Wrong button selection. Otherwise timer is not identified.
Copy following link to help identify timer:
After reviewing timers on link above, please add comment and describe timer in detail, and I can possible locate exact product and give better answer
Gene
h
Aug 08, 2013 | Hardware & Accessories
NOMA 1000 watt Photoelectric Timer manual
1) Copy following link to identify timer and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#N1502
2) If timer has gone defective, then N1502 has 1 year limited warranty.
Timer is rated for 8 amps.
125 volts x 8 amps = maximum 1000 watts
2-prong output.
3) For heavier duty timer, with 3-prong grounded output, choose N1506 timer
Dec 04, 2012 | Hardware & Accessories
Moonrays noma landscape 9 hour power supply. cannot figure it out
You have the 9 hour 200 watt Moonray.
Copy following link to identify timer and see basic instructions by pushing button and cycling throught choices.
http://waterheatertimer.org/Woods-timers-and-manuals.html#Power-pack
Sep 23, 2012 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
Noma outdoor timer 1875
Timer is not identified.
Noma is generic brand name used by different sellers to denote that product is a timer.
Noma is generally associated with Woods timers.
1875 is usually the watt rating for heavier duty timers, like 2 button block heater timers, etc.
1) Add a comment and describe timer in detail, and include photo of timer posted on Flickr for possible identification.
2) Open following link to find same-similar timer
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
Aug 19, 2011 | Hardware & Accessories
How do I program a Noma N1506 timer?
All Woods timers and manuals
N1506 manual:
http://waterheatertimer.org/pdf/Woods-49122-N1506-manual.pdf
N1506 is heavy duty outdoor timer with display screen.
Plug timer in and display flashes C.
Set current time: press Time button once and display shows 1 am
Keep pressing time button until current time with am pm displays.
Dot in lower right corner corresponds to pm hours.
To set timer program:
Press Mode button, display flashes P
Press Time button until desired ON time displays.
Press Mode button again and display flashes E
Press Time button until desired OFF time displays
When programming is finished, press Mode button and display shows current time.
To reset timer, unplug timer for 10 seconds and re-program timer.
Timer must be reset after power outage. Display will warn by flashing C.
Plug lights into timer.
If lights have a switch, switch must be on.
For manual override, press Mode button, and display shows O and lights will be ON until next program change.
To use timer function, press Mode button until current hour displays.
Dec 12, 2010 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
Noma timer - digital three buttons - one for time & two for mode & ? but I can not figure out how to work it - HELP!!!!
Noma/Woods timers are re-packaged under other names and numbers, and appear across several brands.
I don't show a 3-button timer except for Stanley
Stanley 3 button timer:
http://www.amazon.com/Stanley-38468-TimerMax-Extreme-Temperature/dp/B0020ML758
Westinghouse manual seems to match the Stanley timer
http://waterheatertimer.org/pdf/28468_TimerManual.pdf
Woods timers and manuals are shown on page below:
Woods has 2-button timer N1506
Woods has 1 button timer N1502
http://waterheatertimer.org/pdf/Woods-N1502-manual-english.pdf
UPM makes 2-button timer
http://waterheatertimer.org/pdf/DT523-Manual.pdf
Write down what displays when each button is pushed, and then add a comment and I'll try to decipher the buttons.
Dec 12, 2010 | Hardware & Accessories
Timer not working Malibu ML88T Power pack
there are multipul 12 timers on the market BUT if you use a 12 volt power pack designed for a car radio display or even a simple 12v 5 amp laptop power suply and a cheep outdoor timer or cheeper indoor timer and run wires inside you can add lights
remember theise lights are low voltage and if you change the bulbs out you can really strech out the amprage too
low amp led automotive bulbs are a great invention they draw mili amps and use 12 volts
i converted my noma moonrays to a laptop power supply and added 30 more to a single string so i curently have 50 lights on 1 power suply pulling aprox 4.5 amps out of a 5A power supply i used led bulbs and simple moma cord now i can light the whole back yard with 1 ps and it's really bright if i use the led headlamps mounted under the soffit on the house
Aug 04, 2009 | Malibu ML600TW - Low Voltage Power Pack -...
Solar Noma 7 Day, 6 Event Outdoor Timer - Easy To Use +warr Logo
947 people viewed this question
Top Solar Hardware & Accessories Experts
Sheldon Dedek
Gil Shultz
SPAMSITE
Are you a Solar Hardware and Accessory Expert? Answer questions, earn points and help others
