Question about New Bright 384 Holiday Express Animated Electric Train Set
What is the voltage on new bright trains
Repairing or replacing the motor on the locomotive. I need the electric motor voltage for testing. Thx
5 Suggested Answers
SOURCE:
  • 5 Answers
SOURCE: locomotive won't come on
This train set is very particular and getting it to work each Christmas is a family tradition in frustration. First you must make sure that all the pieces of track are connected properly and that the track is perfectly symmetrical and flat. We double-check the battery positions every year and find one in wrong. There are + and - signs, but they're hard to see; use a flashlight. There is a black toggle switch below and behind the red stack that toggles forward (to make the train go forward) and backwards (reverse); straight out perpendicular to the train is the "stop" position. Also, you have to start at a stop/switch station. One other note: behind the red stack, there is a smaller black stack. If you turn this, you can make smoke come out of the stack. I think I remember someone suggesting a drop of cooking oil. Hope this helps!!! Hope you get it set up for Christmas!!!
Posted on Dec 24, 2009
geo5734036
  • 528 Answers
SOURCE: Dear FixYa ... I have a
Is the train new and if not, has it ever gone forward in the time you've had it? Also have you tried putting the train on the tracks facing the other way - what happens?
Posted on Nov 20, 2010
  • 3 Answers
SOURCE: hi having trouble with
Yes, additional track is available from several places, such as Hobbylinc.com, and TowerHobbies.com. At this time, just after Christmas, they are out of stock, however. Walthers.com has them in stock (1-4-2011). You can find extra track on sale on eBay, as well. Be sure to get the track with the brass covers, as New Bright sells battery powered trains that use bare plastic track, which will not work with the 384. A Google search will turn up more sources.
Posted on Jan 04, 2011
SOURCE: I bought a New Bright Timber Wolf & Redwood
It's supposed to be silver metal with a hole in it.
Posted on Jun 04, 2011
Rubber traction band on New Bright no.183 Locomotive, where can I get one?
Go to newbright.com . They have a technical support , or contact prompt. I'm sure they can help., or try customerservice@newbright.net
Jan 05, 2015 | New Bright 384 Holiday Express Animated...
How does a diesel electric locomotive work?
Diesel oil is ignited in cylinders of diesel motor which turns a generator, which powers electric motors connected to wheel axles.
Oct 13, 2014 | Diesel Car Repair Shop Locomotive Shop
Have lights and animation, but not rolling around the track. Driving Wheels of locomotive do not move, even by hand
If the drivers do not rotate under any circumstances, the internal drive mechanism may be jammed.
Dec 10, 2013 | New Bright 384 Holiday Express Animated...
I bought a marklin steam locomotive where the wheels are frozen up or not moving at all. Any help ? Ho can repair it. Thanks
If the wheels don't move even when you try to "slide" them with your fingers, the possible problem is with the motor brushes: with a pair of tweezers gently push the springs that hold the brushes (there is one cooper brush and a carbon brush, on the motor). Remove the brushes and replace them by new ones (available from any Marklin dealer). Notice that there are 2 brush models - for old motors and new motors (these ones use 2 carbon brushes instead). Hope this helps. Best!
Oct 08, 2013 | Walthers Marklin "Veolia Transport" Class...
I have power to the train and it runs but it moves extremely slowly and sommetimes comes to a stop.
I'm assuming the train is track powered with a power pack, and not battery powered, so there's actually a few possible solutions. I'll work from the easiest/cheapest, to the more advanced/expensive.
First, especially if the track is old or been in storage a while, the track may have a thin film of dirt, oil, or rust that is insulating the wheels from picking up the power they need from the track. Try cleaning the track with a mild soap but BE SURE TO DRY IT COMPLETELY before reattaching the power. Also, clean the wheels but use a cotton swab and very little water. One drop inside the motor might destroy it from the inside. You can also try a special track cleaning solution sold at your local hobby shop that has HO model train sets. That will work better, especially on lightly rusted parts. Also, make sure all the track connections are tight and free from contaminants.
Then, if you're feeling brave, you can check the motor of the train itself. Disassemble the locomotive and find the motor inside the housing. Check the wires leading from the wheel area to the motor for any corrosion, or loose/broken wires. If it's not the wires which are easy to solder back in place, I wouldn't recommend going any deeper into the motor as it's better and less frustrating to just buy a whole new set.
Finally, the problem may lay in the power pack (inverter) itself. I personally don't bother trying to fix a power pack, but if you know your electronics you could run some tests of the output voltage to the track, and the voltage on the track at various points. Again, it's not worth the time or effort to mess with the power pack unless you know what you're doing. You could get seriously injured or killed by the voltage/amperage running through those things. They even have enough stored electricity after they're unplugged to cause some nasty electrical burns from the capacitors.
Hope this helps and you're able to fix the problem so you can get back to enjoying the train set. I've always enjoyed watching them for hours, especially when I set up my track around the Christmas tree every year! Good luck!
Dec 19, 2010 | New Bright 384 Holiday Express Animated...
I bought the 6-30089 Pennsylvania Flyer Train Set last year. It's been in storage in the original box in a cool, dry place since last Christmas. I put it together, but it will not run. There is power to...
Hope you got the set working. If not, look underneath the locomotive near the rear (under the "cabin"). There are two switches, one on either side. One says "Smoke", the other says "Reverse". If the "Reverse" switch was set to "Off" when the locomotive was in Neutral, it will stay in neutral even when the power is cycled or the "Direction" button is pressed on the power supply. Even in Neutral, all the lights will work and I believe the smoke element will heat up but won't puff. Whatever setting the "Reverse" switch is on, try changing it to se if that works. Hope this helps...
Dec 04, 2010 | Lionel Pennsylvania Flyer Train Set
Locomotive won't come on
Dec 12, 2009 | New Bright 181 Toy Christmas Train
Forward runs good but reverse dosnt work so good unless you give it a little push but if you slow it down again it dosnt work so good again even siezes. help
You will need to perform the following :
1) clean any and all electrical pick ups (with power off)
2) check, clean, and re lubricate gearing on locomotive
3) check switch on fwd and rev for contact and dust.
4) please note that sometimes this is a really good excuse to buy a new locomotive or upgrade to a BIGGER set.
Hope This Helps,
RSMITH972278
P.S. PLEASE RATE MY ASSISTANCE
Nov 29, 2009 | Lionel Trains Classic Freight Train Set
Need motor brushes for Penn Line and Tyco HO
If you go to :
www.hoseeker.net
they have old catalogs and part numbers for Penn Line trains. Then try:
www.yardbirdtrains.com
for parts or a replacement motor or they may be able to point you to someone who may have the parts. Good luck.
Bob D.
Apr 25, 2009 | Electric Vintage Tyco Ho Scale Trains...
New Bright 384 Holiday Express Animated Electric Train Set Logo
81 people viewed this question
Top New Bright Toys Experts
Colin Stickland
Colin Stickland
Jonah Oneal
gerry bissi
Are you a New Bright Toy Expert? Answer questions, earn points and help others
