SOURCE: TV shuts off
I would suggest that you guys turn the unit off when this happens, unplug the unit for 30 seconds, plug it back in, and see if this helps. If this does not solve your problem, you should call 1-800-448-2244, so a service center in your local area can be found for further assistance.
SOURCE: Hitachi Ultravision Digital 55" hdtv
Good Day;
Try this:
Symptom: All Front LED indicators are flashing in sequence: Power-->Temp-->Lamp-->Power......continuously
Cause: Replace Lamp . This symptom may happen all the time or it may be intermittent. It is normal if it occurrs from time to time, See OG under TV Front Indicators explanation notes.
Good Luck, big IRISH.
SOURCE: WD 52525
This is a sign of a failing capacitor set on the power board. there may have been a small or minimal pulse that went threw the set during the power outage and when the power was restored. this could also be overheating as well due to dust forming on the power boards components. i would remove the back cover and clean as much dust off the power board as possible with some sort of canned air if possible. make sure the cooling system is working properly as well.
please rate and god bless.
SOURCE: TV shuts itself off
Something is overheating or you've got leaking capacitors somewhere. I'd start with the ballast board. Its directly underneath the lamp housing. You can access and remove it through the lamp door. Replace that and if that doesn't solve the problem, comment again, and we'll move on to more complicated repairs. You haven't noticed any weird noises, humming, screeching or similar oddities from the set? Turn the set on with the lamp door open and bypass the switch with a piece of tape, if you hear something like a hum, you may have a bad color wheel motor.
SOURCE: TV won't stay on. Green & Red light timer-lamp (Green) stand by/temp (red) flash.
Most likely needs a new lamp. Easily done yourself.
