Question about Kitchen Ranges
Oven not working
I have a GE Spectra Electric range/oven, the lower heating element burned out resulting in sparking and smoke. I took the element out and wrapped the element wiring leads in electrical tape. When I tried to reset the breaker it keeps popping off. I unplugged the oven and was able to rest the breaker. Do I have to have a new element installed before the range will not trip the breaker and start working again? Is there a possible problem in the oven somewhere else? Why would the breaker not reset with the oven plugged in?
    Champion:
  • 208 Answers
It is very likely that the element has failed internally and as such, the only cure is a new element.
Posted on Dec 08, 2012
  • david Dec 08, 2012
    I am going to replace the element but shouldn't the range still work ? Why won't the breaker reset with the oven plugged in?
SOURCE:
fridgetech
  • 473 Answers
SOURCE: FRIDGIDAIRE RANGE
It is most likely the pop came from a relay on the control board if the elements checked ok but not getting power to them. This is fairly common on fridgidaire ranges. Replace the oven control. Usually the control overlay is sold as a separate piece.
Posted on Nov 12, 2007
SOURCE: Kenmore electric range
You need a new mother-board.
I had the same issue, it overheated my kitchen in a matter of minutes. If I didn't turn off the circuit-breaker, I probably would have had a fire - the heat being emitted was intense. The cost is running around $300. with tax and delivery. I'm not sure if I want to repair or purchase a new oven.
Posted on Sep 25, 2008
ginko
  • 19396 Answers
SOURCE: GE Electric Spectra Oven botton element will not heat
If only one element does not work, then test heating element continuity using a multimeter.
If oven does not bake or broil, then test temp probe.
If there is nothing wrong with elements and temp probe , then test wiring harness to control panel and timer control board.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Posted on May 04, 2009
Maytag317
  • 1136 Answers
SOURCE: 0ne of the surface units does not heat. Frigidaire Electric Range
HI, You will need to change the burner switch. When the element shorted, it took out the switch also. If you need help with part#, please let me know
Thanks
Vic
Posted on May 17, 2009
SOURCE: oven does not work
Its 220 volts and ge only turns of one leg of the 220 vols so you always have a hot side NEVER work on any thing thats still pluged in.
You could have killed yourself if you touched graond while you pushe the hot conecter on to the burner. Try reseting your house bracker If that don't work Look a the relays and wiring in the stove.
Posted on Jul 08, 2009
Should we repair heat element, or buy a new oven?
It sounds like your element is electric. When food drips on that element it can cause a heat spot on the insulation around the electric element and eventually burns through. You can easily replace that element for about $50 - $60. It requires about three hand tools and 15 minutes to remove old one and install a new one. You should be in business for another 14 years if you clean any drippings on the element itself.
Mar 10, 2014 | GE Profile Spectra JBP95 Electric Kitchen...
The coil in my oven caught on fire
You will need to replace the element, If it was just the lower bake element, it is a very easy repair, two screws and two wire connectors. UNPLUG the stove FIRST!!
Jul 01, 2010 | GE Spectra JBP78 Electric Kitchen Range
Oven partially heats
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Feb 03, 2010 | GE Spectra JBP78 Electric Kitchen Range
Heating element in the oven appears to burn out, can it be repla
yes but be sure to turn the breaker off or unplug the stove cause the element has power on it on one side all the time and will short out when you take it out. you should see a screw on the plate that the element is attached to in the back of the oven that is how you get it out..
Sep 27, 2009 | GE Spectra JBP78 Electric Kitchen Range
Need part number for lower heating element in a JBP26 oven
That doesn't appear to be a complete serial number. You can go to repairclinic.com and click on repair help, or go straight to this page: http://www.repairclinic.com/0089.asp?apptype=13
to find the correct serial number.
Jul 20, 2009 | GE Spectra JBP78 Electric Kitchen Range
Dec 20, 2008 | GE Profile Spectra JBP95 Electric Kitchen...
Electric Oven not getting hot enough
there are relays on the oven control that turn the elements on and off, sounds like you need a new control
Feb 05, 2008 | GE Spectra JBP78 Electric Kitchen Range
GE Electric Range
It is very common for elements to "catch fire" when they fail. It is really electical arching. But to answer your question you shouldnt be concerned if it ever happens to the bottom element immediatly kill the breaker it will stop instantly. dont use a fire extinguisher as it wont stop the arching. And most ovens do use the upper broil element for baking for very short intervals like 10secs on every minute or so to brown the top of product. Some models (especially older builder line ) do not
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
140 people viewed this question
Top Kitchen Ranges Experts
Craig Butler
Craig Butler
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
