It,s not showing anything except a whitescreen but the sound is still in there.
SOURCE: NOKIA 6630 displays not charging when connect charger
hi dude,
>>> dont remove any thing from u r mobile, first confirm the problem where it is...
>>> first try to put the charge by using other charger... still u r getting same problem means change the charging unit
>>>good luck... thank u....
>>> dont forget to rating the solutions...
SOURCE: display problem
Your display circuit is broken, even if the LCD-panel,
seems to be ok the display is damaged.
This is a very common problem in Nokia phones.
The only way to fix this is to change the display.
You need a T-6 Torx Skrewdriver to do the job.
You can find displays for fair price at :
www.mytrendyphone.com
This is your solution! Please vote!
