I bought 2 Kenwood KFC's and i have been powering them with a Legacy la-2078 2400 watt amp. For the past 2 months or so the subs worked great, but jus recently i tried some customization by changing the box the subs were in. it sounded bad so i changed the box back to the original one. Somewhere in the mix of changing the boxes something went wrong because now when i have everything hooked up, both subs barely work and it sounds bad. if i unplug one of the RCA cables or one of the subs, the other one pounds as hard as it should.
I have unplugged and secured connections of all wires but there is still no change in performance.
it is severely depressing.
You most likely mess up you wiring... im not sure what ohm resistance your subs are, but if its 2ohm or 4ohm you wire straight foreward one sub all positive wires to left positive, all negitive to left negitive, and the same with sub 2 to the right terminal. BUT if your subs are 8ohm then wire it with all positives from both subs to LEFT positive and wire all negitive wires to RIGHT negitive... and see if that helps and good luck!
I almost know that its the amp. Because each sub works individually if i unplug the other one. So that would mean that the connections are good but the amp cant power them both at the same time with the same consistency.
