I reset the settings and now the picture looks aweful
SOURCE: Toshiba 43 inch projection set
Possible bad solder connections in convergence circuit or vertical deflection circuit. This happens in alot of equipment. After warm up, expansion of joint pulls connections loose. Recommend not running like this, could cause component failure.
SOURCE: Toshiba 55" rear projection
Hi, convergence circuit has failed, the IC`s will have to be changed,possibly a couple of precision support resistors as well and the set will then need to be re-converged, More questions? feel free to ask away, Happy Holidays, BMW Rider
SOURCE: 2004 toshiba 65hx83 projection tv
How do you know when your light bulb has burned out? I have sound with a black screen
SOURCE: toshiba 55 inch hdtv lamp
this is a crt type tv- no lamps just crt's if it was moved recently then a seal could have been damaged on the crt cuasing coolant to leak down the neck getting into the socket. this will cause trouble for sure also could have a crack in the crt. look for a sticky liquid in the bottom of the unit.
sometime the crt's can ark and rip out a video output chip on the crt socket check it out.
not common but not unheard of.cheers
SOURCE: Toshiba 50H82 rear projection TV adjustment
The ser needs to be converged in the factory service mode
thanks for the consideration, but i managed to fix the problem with a couple of hours and lots of patience!
