I have an LG Intellowasher WD14125RD and there's a DE error message and doesn't start a cycle.After starting any program the DE error comes on, the water starts running but after a few minutes stops, the drum doesn' turn, and then the miachine turns off - the DE error stays on, what can be wrong? where can I find a manual?
Thanks
Your washer machine works fine it's a position problem of the drain hose. LG official solution:
dE is drainage failure this means that the water will not be drained when drain hose is not correctly connected. Please see the image in this link of official LG site: LG Help Product Support and Troubleshooting LG Africa
Other error codes and solution you can find here:
Product Support
For all those who have LG machine and donot have a match for the door especially top loading this de error means the magnet of ur door is missing which right in front of u in a plastic mould . Search for it in the machine or else attach a new magnet . This is again only for top loading fully automatic without latch door LG model wf t7066mn. Thanks
Problem with the door switch. kindly check door switch ,same harnest door swich & drain motor. if door swich is ok. drain motor & door swich wire might shorted.
DE is for a door lock error and you will need to replace the lock. Here is the part to order.
SOURCE: I have a LG Intellowasher
'dE' stands for 'drain Error'.
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Your timer swicth is defective or fuse inside but check first the cord if it not broken before you go to fuse and timer
SOURCE: my lg intellowasher 7kg WD-1059 FB will not pump
Pump motor is probally shot, Mine is 4 years old I'm replacing mine again. Yes I've replaced it twice
