JBP78W electric smoothtop small burner in dual burner not working
The smaller burner of my dual burner does not work, but the
large burner does. The surface unit light does come on when I am switched to
the smaller burner, but it does not heat up at any temperature. When in the
large burner mode, the small burner does not work at all either. I have
the GE JBP78W model. Would would you recommend I do first.
The burners are controlled by switches, that are the one you turn when you turn the knob. Iwf the burner does not switch to high mode than you need to change the switch. The switch for your appliance has part number: WB21X5243 You can by the part from manufacturer clicking here.
Here is an exploded view of your kitchen panel.
The switch is indicated with number 3 in the picture, There should be at least ttwo of them, depending on the model. That is what you need to replace. Its price is $40.50 from GE.
If our posts had been helpful do not forget to accept the solution.
http://www.consumerreports.org/cro/kitchen-ranges.htm
Freestanding electric smoothtop ranges are the big sellers, but you have more choices than ever. Our Ratings include smoothtop ranges, of course, but you'll also find induction and coil-top ranges in the electric category, along with gas, dual-fuel (gas cooktop, electric oven) and pro-style ranges. Choose a single oven or double-oven range, freestanding or slide-in. We test all of these. Consumer Reports offers you buying advice that you can trust. We provide unbiased Ratings and range reviews to help you choose the best range for your needs and budget, and use our buying guide to learn more about range types and features that matter most.
Ratings & recommended kitchen ranges
Electric smoothtop ranges (62)
Our Recommended ranges can do it all and, based on our survey of thousands of readers, do not have brand reliability issues. The Recommended ranges will bring pasta water to a fast boil, hold a big batch of spaghetti sauce or chili at a low simmer, a... More Recommended electric smoothtop ranges Electric smoothtop range Ratings
Electric induction ranges (9)
Our Recommended ranges can do it all and, based on our survey of thousands of readers, do not have brand reliability issues. The Recommended ranges will bring pasta water to a fast boil, hold a big batch of spaghetti sauce or chili at a low simmer, a... More Recommended electric induction ranges Electric induction range Ratings
Electric coil ranges (10)
Our Recommended ranges can do it all and, based on our survey of thousands of readers, do not have brand reliability issues. The Recommended ranges will bring pasta water to a fast boil, hold a big batch of spaghetti sauce or chili at a low simmer, a... More Recommended electric coil ranges Electric coil range Ratings
Gas ranges (43)
Do you love cooking with gas? Our Recommended gas and dual-fuel ranges (which pair a gas cooktop and electric oven) are top scoring and, based on our survey of thousands of readers, do not have brand reliability issues. They have large cooktop burner... More Recommended gas ranges Gas range Ratings
Pro-style ranges (34)
Pro-style ranges are stylish, stunning, and make a statement. But despite their high price, they aren't the best ranges we've tested. So before you swipe your credit card check our Ratings. You'll see the top brands, including Viking, Wolf, Thermador... More Recommended pro-style ranges Pro-style range Ratings
I tried to find your specific range by Google search, but the only reference to the "jeco----------" is on this forum, so I couldn't determine whether this stove is a gas or electric model.
IFyou are talking about an electric stove burner, then either one of the elements is malfunctioning or broken, or the contacts are dirty or otherwise not making good connection to the stove's burner receptacle. The way to check this is to remove the burner element and swap the similar element into its place to see if it works properly. Assuming the receptacle is not dirty or contaminated with debris, the burner should work normally. If it doesn't (but DID work in the receptacle you pulled it from) then either the receptacle itself is dirty/corroded/contaminated, or the control switch is bad.
My gas oven stopped working properly - called in the repair man and he replaced two of the three ceramic ignitors. (I have a two oven model). Apparently they only last / work well for 3-5 years. Kinda sounded crazy to me - but verified on the internet they are required to be replaced. Not sure I'd call the repair man next time - get the part yourself, one screw & two wires to replace. I'm no expert - but that solved my problem.
the inner burner is broken so the whole thing needs to be replaced. check your owners manuel for warrenty times on the burner. otherwise just replace the burner and that will solve your problem..
same as above but I have a Whirpool flat top range
