Looking to re-install lost original secure software for my jds128-40-520c
SOURCE: how to save my documents to lexar 2gb jumpdrive
You can simply drag the My Documents to the drive, that will make a copy. But you could also use the backup function of Windows (simply type 'backup ' in the Windows help and follow instructions).
Jules
SOURCE: When i plug in the jumpdrive on any computer it says USB device not recognized, please help
Well, it’s a super simple solution! No need to edit the registry, uninstall drivers, or anything of that sort.
Simply UNPLUG YOUR COMPUTER FROM THE POWER SUPPLY
Yes that’s it! Note that this does not mean just turning off your computer because modern computers don’t really turn off when you press the power button as the motherboard still gets power.
First to explain, the motherboard is where all of hardware of the computer is connected to, including the USB ports. Sometimes the motherboard needs to be “rebooted” also because something can go wrong, i.e. all your USB ports suddenly stop working. The small microprocessor on the motherboard will reload the drivers and your USB ports should be back to recognizing all devices!
So first turn off your computer using Shut Down or pressing the power button and then UNPLUG it from the wall outlet. Let it sit for about a minute and then plug it back in.
Hope this helps someone fix that pesky “USB device not recognized” Windows error!
P.S. if it is a laptop, power up the laptop with just the batteries, not plugged in to fix this issue.
Give this a try and come back to tell us if it worked or not.
