Question about Maytag Neptune MAH5500B Front Load Washer
Tub fills with water
Maytag neptune mah5500bww tub fills with water when not in use
  • 375 Answers
Replace water valve in the washer. Serial number is needed to find the correct part number. It's likely 22003834, but call any parts supplier with model/serial numbers to verify.
Good luck,
Vlad
First Choice Appliance
Posted on Nov 02, 2010
SOURCE:
How do i replace bearings on Maytag Neptune model MAH5500BWW?
Here a website for you with a video that will assist you in this repair.
Good Luck
Maytag Neptune Bearing Replacement How to Replace Neptune Tub Bearings
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 09, 2014 | Maytag Neptune Washing Machines
I have a Maytag Neptune Model #MAH5500BWW, and it leaks water only while it's filling. It's almost like it would rather fill my floor than the tub. When I start a spin only cycle to get the water...
Sounds like a leak either in the bottom, connector or water valve for your water inlet line. Visually finding the leak is your best bet, then you know what parts are to be replaced.
May 26, 2011 | Maytag Neptune MAH5500B Front Load Washer
I have a maytag neptune MAH5500BWW. Everytime the water company shuts off the water to repair a leak, the tub fills with water, sometimes overflows onto the floor. Works just fine when there is pressure...
This is symptomatic of a malfunctioning water control valve- depending on whether it is hot or cold water with which the tub fills.
Sorry but it needs replacing and a service call ;-0(
Good luck,
John C
Mar 27, 2011 | Maytag Neptune MAH5500B Front Load Washer
Hi I have a Maytag Neptune model MAH5500BWW Serial B4585662GA. When I turn the drum, I can still hear water inside/behind the drum. Thank you
This is normal. There is a balance ring filled with water attached to the inner drum. The balance ring is sealed and is not supposed to be empty. When you turn the inner drum by hand, you're hearing the water settling down from the now upper chambers of the balance ring.
Oct 14, 2010 | Maytag Neptune MAH5500B Front Load Washer
I have a Maytag Neptune model # MAH5500BWW. It appears that there is still water inside the tub after completing a wash cycle. I only noticed it as I tried to get a stuck sock from the top of the tub and...
the noise you're describing is normal - there is water in a sealed balance ring on the inner tub. To get rid of the mildew and smell, leave door open after cycle and use something like Affresh or "Smelly washer" stuff monthly or more often.
Vlad,
Aug 13, 2010 | Maytag Neptune MAH5500B Front Load Washer
Have a maytag mah5500bww replaced door lock still do and fl code
fl is usally a water not detected problem,, check ur fill hoses for kinks make sure ur water is on,, possibly have a bad fill valve..
Feb 05, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500BWW burn smell (doesn't appear to be hose)
if you have a maytag neptune washer that ran up until now you got your money's worth,that's the machine that put maytag out of business,if it's smoking and ripping the boot it sounds like the tub bearing is gone and you'll have to replace the washer,if it's load in the spin like marbles are rolling around in it that's the problem,but i wouldn't put a cent into that machine.
Oct 06, 2017 | Maytag Washing Machines
Maytag Neptune Front Load Washer Model MAH4000AWW low last spin
two problems here,
your shaft seal is running on its last leg
the sound is unmistakeable and always described the same...
the water issue, you probably have a trickle leak through the cold water valve
the mixing valve is quite an easy repair, but I would have to say with all honesty, it probably time for a new machine
the hub seal is a tub replacment call
2 hrs of labor if hes good
and the tub runs around 500.00 dollars
sory for the bad news
Oct 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune washer, model MAH5500BWW, not spinning up to speed
Open the lid. take one hand and push the tub back toward a back corner. Take your other hand and fill in the gap on the opposite corner. There should be a black round rubber strap going from the outside top of the tub to the cabinet. Once you find it check all four corners. I feel sure that you will find more than one broken. These help to keep the load balanced. It is very important that you change these as soon as possible due to after these break these machines are bad about the tub banging into the sides and cracking the outer tub. To replace the tub will run ( in my area) around $240 - $300. These straps are not hard to replace and don't cost very much. I would rate replacing them a 2 on a hardness scale from 1 to 10. 10 being the hardest.
Please rate this solution if helpful.
Aug 21, 2009 | Kenmore 42182 Top Load Washer
Maytag neptune mah5500bww leaking water
Here is the solution I found that worked for me, there is a small drain hole at the bottom of the boot that is connected to a drain hose. Remove the hose and clean out to make sure that it has not become plagged. replace hose and reattach boot. Mine stoped leaking imediately.
Feb 22, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
418 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
