JBL (JBLRADIALWHT) Speaker System, Docking Station Adapter for Apple iPod Logo
Anonymous Posted on Jan 12, 2009
JBL Radial Remote stopped working.New battery replaced no avail.
JBL Radial Remote stopped working.New battery replaced...No change.Ipod and docking working ok.Only remote.Any help appreciated.
shanti
  • 7 more comments
  • Brianh1949 Jan 12, 2009
    As the above, mine was working one day. Then next day it failed to activate the Ipod. The blue light on remote responded to key presses, but nothing happened. Bought new battery to no avail.
    JBL manual says to reset ipod but I don't want to lose my settings and wifi after all the trouble setting it up-especially if that does not fix problem
  • tpercival Jan 13, 2009
    I've got the same issue. Remote worked fine this weekend. I tried to use the remote today, and while the orange and blue light on the remote worked fine, the dock/iPod did not respond to any of the remote commands. I replaced the battery, and still nothing.
  • Anonymous Mar 18, 2009
    I have tried the procedure above and got no resolution. Is there a place that I can buy a new remote?
    My llights on the remote do not light up when I presss the keys.
  • Paul jones Oct 07, 2012
    Have you guys found out about the problem? I have the same issue.
    I have the same problem as above, but none of the above helped me. Any further suggestions?
  • Anonymous Oct 08, 2012
    Turn OFF at the Mains for a minute or two.Than turn it ON.It worked for me.
  • Denise Hutter
    Denise Hutter Feb 09, 2014
    open the remote case, remove the battery tray and look into the remote opening. Near the back, you will see a silver battery bar. Pull this forward to make sure that it is contacting the battery. This solved my issue.
  • Denise Hutter
    Open the case and remove the battery tray. Look into the back of the remote and you should see a silver bar. Pull this toward the opening to make sure it is contacting the battery. This solved my issue with intermittent work/not work issues.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Mar 11, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
4737
Points
49
Turn on the JBL with the ipod in place, turn off at the mains plug, turn back on, turn on your JBL and the remote should work.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 15, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
4032
Points
I suffered the same inconvenient situation regarding my remote i-pod (touch) relationship. Oh... and even after the above recommended solutions failed time & again... What a waste... I soon stumbled upon the misbehaving diagnosis of what i was experiencing.. Whilst performing an extensive brainstorming session on my balcony, clutching a smoke as result of frustration. The thought of removing and simply inserting the same battery to successfully insure functionality was as phenomenally impossible to me as much as this might sound to you. Eureka...!!! For some inexplicable reason the remote is now perfectly compatible with both i-pod (touch) & JBL Radial... If the above mentioned solutions inevitably proves disappointment, see if this works for you...!
I have a radial ipod doc. Today I have docked my ipod and pressed play and all I get is a hiss - like static. I have tried using the buttons and the remote to increase the volume/stop start. They seem...
I had the same problem, my dock was broken, but I got round it instantly by plugging my ipod into the speaker via the headphone port on the ipod and into the audio in port on the speaker. When new, the speaker actually came with a spare lead as you can plug any mp3 player into it this way. The sound quality seems exactly the same and I dont have to throw away the speakers, hurray! If you have lost the lead you need a 3.5 mm male to male headphone lead, just pence in any electrical shop or amazon.
How do I connect my radial JBL to laptopp, i.e. how i get the sound from my laptop on the JBL pls?
i need to connect my ipod docking device to my laptop in order listed my music from the laptop louder throygh the device. i bought a usb cable in order to connect the lap top to the jbl device ?
3helpful
2answers
No picture on television when connecting s-video outlet from JBL radial and showing a film or pictures on a docked i-pod touch.
Hi, I have this problem and when I spoke to JBL techical support they told me that Apple have changed their software on the New Nano and the ipod touch and of course the iphone and regrettably the radial does not support S video for these products. I'm told it will work with first generation ipod classics. PS: i had to carefully cut off some of the plastic plug to make sure the connection goes all the way into the back of the radial
3helpful
4answers
Jbl radial dock connector broken
I have the same problem, but I got round it instantly by plugging my ipod into the speaker via the headphone port on the ipod and into the audio port on the speaker. The speaker came with a spare lead as you can plug any music player into it this way. The sound quality seems exactly the same and I dont have to throw away the speakers, hooray! If you have lost the lead you need a 3.5 mm male to male headphone lead, just pence in any electrical shop or amazon!
2answers
My jbl radial, when using a 120 gig ipod, will skip songs.
Not a solution but mine sometimes causes my ipod to skip mid-song to the next song or podcast as well. JBL customer service is usually good and I've been meaning to check with them since I finally figured out it's the radial and not my ipod.
1helpful
JBL Radial Remote Doesn't Work
Unfortunately, this is a fairly common problem with many small consumer electronics. The way that the devices are manufactured, there is an IR receiver that is soldered onto the PCB inside the unit. Sometimes this circuitry fails. There aren't any options on the Radial that would turn the option the remote off. Your best bet is that if the unit is still within the return period of the store you purchased it at, to return if. If it is outside of the return policy, I would give JBL consumer line a call to get the unit serviced, or get a replacement. Good Luck!
5helpful
2answers
The remote with JBL Radial iPod player no longer works
Turn off the JBL at the mains, turn it back on then turn on the JBL, the remote should work it did for me.
2helpful
2answers
Compatability with 4th gen nano
I have had exactly the same problem having bought a JBL Radial Micro for my partner for Xmas for use with the Ipod Nano, i contacted JBL via their website and was advised to contact Harmen on 01707278100. I was advised that the new ipod nano (chromatic) would not charge on the JBL radial micro. They stated that this was due to Apple changing the charging pin in the new nano. I have since bought a JBL Stage III. I contacted Harmen before buying this and was advised that the Stage II would not work. Hope that this is of use.
Top JBL Audio Players & Recorders Experts
 Grubhead
Grubhead
Bob Kirkwood
ADMIN Andrew
ADMIN Andrew
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
