SOURCE: change toner error brother 2820 mach has new brother toner ctg
with machine on, open front cover, press the "options" button, you should see "replace drum?" press the "start" key then 1 then 0. display should show accepted for a couple of secs. then show cover open. close front cover and message should be gone. if not, you will have to contact Brother.
hth,
razors
SOURCE: TONER LIFE END APPEARS ON LCD
try opening front door, press "options" then "start" then "1" and "0". if screen shows accepted, you're good to go. close front cover.
hth,
razors
SOURCE: Changed the Toner in Fax Machine and Still reads "Low Toner"
First, the obvious
Another thing to check is cleaning the Corona wire inside by sliding the Blue tab back and forth several times. Important to return the Blue tab back to the "Home" position afterward.
If you've done ALL of these steps correctly, and the low toner message is still there, a service call is in order. Best of luck with your machine!
SOURCE: can't reset "change drum soon" message Brother Fax 2820
Open the front cover and press and hold -stop,reset button
