I assume you are replacing the built-in Audiobahn power amplifier with your 4 channel Soundstream amp. If so, you can set the Soundstream for bridge mode which should net you 2 high power channels of 250Wrms@4ohms or 500Wrms total power (if the speakers are quad VC), or alternatively, non bridged for 4x125Wrms (if the speakers are dual VC). You can see why below.
Next, you need to confirm each subwoofers coil configuration as follows: If each woofer is quad, there will be 8 connectors; if dual VC, then there will be 4 connectors. For dual VC, if each VC is 4ohm, you can choose between 8 or 2 ohms by series or parallel wiring. If each VC is 2 ohm, you can have 4 ohms in series to use. This can be determined with an ohm meter across one set of VC terminals. If you can get 4 ohm for each speaker, this will allow you to use the 2 channel bridged mode with each speaker getting the full 250W. If each VC is 2 ohm, use non bridged mode and run each of the 4 channels to each VC. For this case, use a 2 to 1 RCA jack to sum the two channels for each speaker on the amp's input side to make the signal 2 channel instead of 4 channel. Below are examples of quad and dual VC for reference only, the wiring may not match your setup which will depend on your VC resistance (impedance) measurement. Don't forget to set your HPF(High Pass Filter) as this is a subwoofer setup.
