The Polaroid FLM-3201 units have a known issue with the filter capacitors on the power supply board. When the filter capacitors go ou tthe power supply can not start up so you get no power to the TV. New boards are not available any more but you can repair the board in your TV by replacing the filter capacitors. If you can a little soldering then you can do the repair yourself. Here is a picture of the power supply board with the filter capacitors circled in yellow and below the picture is a link to get a kit of the needed capacitors.
http://www.ccl-la.com/catalog/product_info.php?products_id=239
I hope this helps,
BuddyMc
