SOURCE: 84 Porsche 944,Stopped running while driving, will not turn over
check the timing belt. this auto is a valve bender.
SOURCE: renault megane 1999 whirring noise from engine ,car wont start
sounds like your timing belt has snapped, allowing the engine to tutrn over but the belt is not turning the vales, hence no start
SOURCE: 91 buick regal 3.8L is making a loud clank noise in belt area
did you check all the pulleys for smooth operation and looseness? did you check that the crank pulley and damper are OK?
SOURCE: engine died.won't start.
Sounds like your crank sensor is faulty.These engines are known for crank sensor and ingition control module problems
