No matter what settings I use, the last page always prints first. The Collate option is dimmed out so I cannot select it at all???
SOURCE: scanning from Canon MP530 to Mac Powerbook
If you;ve installed the MP Navigator software from the CD, then you should be able to press the scan button on the printer with your Mac connected and the MP navigator will open automatically on your Mac ready to scan. You can also try going into Preview (the Mac app) and from the file menu select Import... and it should open a scan window. Hope this helps!
SOURCE: Printing a book from Word using duplex printing
In the Printing Preferences window, on the Page Setup tab, you have already selected Duplex Printing and Automatic. If your book is to be bound on the long side, you should have 'Long-side stapling . . ' selected in the window below that.
If that is what you have selected and the pages are printing wrong, try the 'Short-side stapling . . .' option.
SOURCE: canon pixma mp530 all-in-one printer set up
Receive Mode Setting
On the operation panel, press the following buttons to select the appropriate receive mode.
Solution:
Changing the TX report MP530
FAX ONLY MODE: When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only.
MANUAL MODE: When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually.
ANS MACHINE MODE: When you want to receive voice messages on your answering machine and receive faxes automatically.
FAX/TEL AUTO SW: When you want to receive faxes automatically as well as voice calls.
DRPD: When you have subscribed to a DRPD service with your telephone company.
Change the TX Report
1. Press the <Menu> button to display [FAX SETTINGS].
2. Use the [ ] or [ ] to select [TX SETTINGS] then press <OK>.
3. Use the [ ] or [ ] to select [TX REPORT] then press <OK>.
4. Use the [ ] or [ ] to select [PRINT ERROR ONLY] or [PRINT FOR EACH RX] then press <OK>.
5. Use the [ ] or [ ] to select [YES] or [NO] for [ATTACH TX IMAGE:] then press <OK>.
6. Press <Stop/Reset>.
Changing the Paper Size, Type and Source
Changing the Paper Source
Before
printing, confirm that the location where you have loaded paper is
selected as a paper source. Press <Feed Switch> to change the
paper source.
(A) Auto Sheet Feeder Lamp
(B) <Feed Switch>
(C) Cassette Lamp
Note: Press <Feed Switch> so that the Auto Sheet Feeder Lamp lights when loading paper in the
Auto Sheet Feeder and the Cassette Lamp lights when loading paper in the Cassette.
You can also select the paper source with the printer driver when printing from the
computer.
Changing the Page Size and Media Type
Note: The asterisk <* > on the LCD indicates the current setting.
1 . Press <Paper>.
When you do not need to change the page size, press <OK> to proceed to step 4.
2 . Use to select the page size: A4 / B5 / A5 / 4x6 / 5x7 / C-CARD / 8.5x11 / 8.5x14
3 . Press <OK>.
4 . Use to select the media type: PLAIN / PHOTO PRO / PHOTO PLUS / MATT PHOTO / GLOSSY
Note:
In order to obtain optimal quality print results, when copying
photographs, use Canon-recommended Photo Paper Pro or Photo Paper Plus
Glossy.
5 . Press <OK>.
Entering the Date and Time
Note:
When your machine is connected to a computer with the MP driver
installed, even if the date and time are entered from the Operation
Panel of the machine, the date and time will be read from your computer
every time you start the computer, turn the machine on, or disconnect
and connect the USB cable. When using your machine connecting to your
computer, set the date and time on your computer precisely.
The
date and time will be reset when you disconnect the power cord or there
is a power failure. In this case, you can set it again on the machine.
Alternatively, it can be read from your computer and set on the machine
by connecting the machine to your computer with the MP driver installed.
1. Press [FAX], then press [Menu].
2. Use [ ] or [ ] to select <USER SETTINGS>.
3. Press [OK] two times.
4. Use the numeric buttons to enter the date and time (in 24-hour format). Enter only the last two digits of the year.
Note: If you misentered the date and time, use [ ] or [ ] to move the cursor under the number to enter the correct number. Three formats of date are available.
5. Press [OK].
6. Press [Stop/Reset].
I hope it helps!!!
SOURCE: Canon PIXMA 530 grinds away
I had a persistant grinding noise about 30 seconds after the printer finished printing. It's been going on about 2 months. I did one thing which seemed to work. So try opening the cover on the back of the machine by lifting upward on the gray lever in the middle of the back of the machine. Leave this cover open during and after printing. The grinding noise went away.
SOURCE: How to check total printed pages in canon LBP2900B printer
press resume button at least 4 seconds
