After installing fresh batteries, I press the power switch and it only blink red, it never turns green.
SOURCE: Removing the switch/ button
popo the switch out a solder a pice of wire that bridges over the switch, that way the switch is always bypassed
SOURCE: This is not syncing with my pgx4 receiver The
Look for a possible source of interference.
The unit is likely FM and an FM receiver will "capture" the strongest signal right one or not.
Key is to find which of the two components is faulty. The green LED's really mean very little... other than battery and carrier received.
If you can find another system to isolate which is failed, then progress can be made.
Call Shure Applications at 800-516-2525, prompt 3. They can help you troubleshoot.
SOURCE: I have a well used shure pg58 that wont turn on.
It's hard to tell what might be causing the mic to not power on. It would be best to send the mic to Shure for repairs. Contact Shure Service.
