Computers & Internet Logo
daniel teegarden Posted on Dec 06, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Setting time, date on power book g4
Need to set time and date
Jim Thomson
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Master 1,099 Answers
  • Posted on Dec 07, 2012
Jim Thomson
Master
Level 3:
Renaissance:
Answers
1099
Questions
0
Helped
276072
Points
2710
I'm taking it that you are running system 10 so go to system preferences under the apple menu, then go to date and time under System. Go to time zone and allow the time zone to be set automatically and then go to date and time and set the date and time automatically. If you want to set the date yourself you can uncheck the set date and time automatically and then select the date and then the time using the up and down arrows. Hope this helps.
Take power cut,set time/date from one of my phones.
Go to the manufactor and get the instruction book. Most have online
website to download th einstructional booklets from almost always for free. .
I need to recover yahoo mail account paasword
Go to Yahoo Mail and click on "Forgot Password"
You can then get help by answering the challenge questions or through the alternative email address or you mobile phone,depending how you set it up.
Hi , i've HP ML370 G4 server , after power failure , the server can't boot . i try to reinstall memory & remove all parts & fix it agian but the problem still there , then after about 1 hours it's...
It may be that the lithium battery is dead; usually a CR2032 button battery. Signs of CMOS Battery Failure Dom Tech Computer Blog
Go into the BIOS settings during initial power on boot up, often F10 or F2 are common. Check the date and time, if they are off, you should be able to temporarily boot by setting the date and time but you'll have to do it every time you boot. If the date and time is off, and you set the correct date and time and it still doesn't boot, you'll want to make sure it's booting to the correct drive.
When it doesn't boot, does it give you any error?
I have a powerbookG4 and the caps is stuck on and when i try to type password it types what it wants, wont delete. i noticed the date is incorrect, it says december 1969. i also forgot my master password....
1. Obtain a Mac OSX install disc (buy one from apple or try Ebay) 2. Insert the disc then click on the "Install Mac OS" icon. Then click the restart button. 3. DONT INSTALL! Just click through enough of the windows to get to the regular set of choices on the menu bar. One of those choices is UTILITIES and one of the choices there is RESET PASSWORD.
Simple, but you should know that anyone with a Mac OSX install disc can gain access to your computer.
I got this from another post by gvape. This will work to reset your password so that you can reset the time and date. If this make no difference to your keyboard issues I would look at replaceing the keyboard.
Let me know how you get on.
7helpful
2answers
Date setting for cash register casio TE-100
Turn key to program mode. Type date as YYMMDD Press X/TIME (maybe labelled X/ DATE TIME) Press CLEAR ---------------------------------------------------------------------------------------------------
For those of you needing a Casio TE-100 manual, c-tech has it here:
http://the-checkout-tech.com/manuals/cashregisters/Casio4.php
2helpful
My powerbook G4 won't boot up.
Yes, there is an internal battery that keeps the time, it is called the cmos battery and belive it or not, if the time is not set, it won't boot, you can get a cmos battery for your laptop pretty cheap on ebay, and east to install, just pop the old one out and put the new one in, must open the laptop to do this, or take it to someone to do it for you.
Cannot get time or date into my nokia2630
u dnt need tht book.. open ur phone. menu->settings->date&time settings->ntr ur time and dat
if u want it to be updated by ur network then turn automatic time update on
2answers
Setting my watch
Hi go to www.casio.com/support under technical support choose manuals.
Jvc gr-d370as - help connecting to Mac - Date and Time Setting
hi there on the front there is a small wheel turn your switch to the letter (m) then press down the small wheel on the right of machine, this will give you the menu so you cant change date from that hope that helps
mike
Corrupt Date Book Fixed
Updated Instructions Simple fix for a corrupted Date Book sync error (at least it worked for me on my Treo 650). 1). Turn off 'Show Calendar Event' in the Phones 'Options - General Preferences' menu. 2). Turn off phone. 3). Set the Date/Time to the maximum limits (12/31/31) in Preferences. 4). Open the Calendar and view the maximum day 12/31/31. 5). Select 'Purge - (Delete events older then 1 week)' in the Calendars Options menu. 6). Reset the Date/Time to the current day in Preferences. 7). Hotsync (Desktop Calendar overwrites handheld). 8). Hotsync again to make sure you don’t get the error (Synchronize the files). That’s it. =============================== Outlook Calendar The attempt to open the database failed. Date Book application database is not found. Please invoke the Date Book application on the handheld once and re-synchronize. OLERR:05-0001 OLERR:0D-0004 OLERR:0D-0001 - Not Synchronized Outlook Calendar synchronization failed OLERR:15-0002 OLERR:06-0001 ===============================
Grand Canyon Tech
Grand Canyon Tech
