Both of my cordless phones find the base and lose the base seconds after.I tried unplugging the batteries and plugging them back in. I unregistered the phones but now the phones cant find the base long enough to re-register. What can I do??
Batteries. I had the same problem. Replace the bateries.
Had the same problem and replaced the battery. budgetbatteries.com had the cheapest ones. But it's a knockoff, so I don't know how long it will last. So far it's been 3 months and the problems are gone. I would try that first and see how it goes. I paid about $15 including shipping. If you buy it from vtech it's at least double...
After replacing the batteries in all 4 of my units and the base, I have eliminated the dropped calls and searching for base issues.... for now. Even though these batteries are supposed to last more than 2 years, the fact that they are constantly being recharged when the remotes are in their cradles is a life shortening practice. The more you charge a rechargeable battery the faster they will fail. As an electronic designer I would suggest to V-tech that the cradles only charge the battery when it is almost dead but this, of course, would be more electronics in the cradles and more money for the units. The best solution is buying batteries as needed, several at a time online to avoid the high brick and mortar store prices.
Tried the same - battery solution.. my phone is 1.2 years old. DO NOT BUY A VTECH PHONE - they look nice, but they are JUNK! And the speakerphone sucks.
I've tried everything to fix this. These phones last two years max. The only resolution I've found is buying a new phone system. I'll never, ever buy a vtech again.
There is no solution! This phone is a lemon and even the VTech customer support admitted as much, stating that the batteries are underpowered for the phone and basically expire in one year. So if you want to keep your phone, you'll be forced to either replace the battery each year (I have 8 handsets, gets pricey!!!) or walk away from a considerable investment after only one or at most two years of use - painful......
It is my understanding that lemon laws apply to all consumer products. Hiding behind their 12 months warranty is the wrong tack for this company to take. Some clever lawyer will come up with a class-action suit.
I have two handsets, one of them recently starting dropping the connection to the base quite regularly [even if it was just inches away], and I ended-up in the same situation after unregistering the phone.
In my case, I was able to remove the battery from the phone [as you did] but also unplug the power on the base unit for several seconds. After restoring power to both, I was able to re-register the handset and it appears to be working more reliably now.
can't find base??????/
anyone reading this don't buy these phones they are no good V-teck is Sh?T
cant find base
the message 'searching for base' comes every time i pick up the handset as a result i cannot dial out
I have the exact same problem. I've had the phones about 1 1/2 years, now they're always dropping calls and are very unreliable. It's the pits because I first thought the phones were very cool and was willing to pay a bit more for the features.
have the same problem. can't find base as result can't dial out. How do you fix this problem?
I have the same problem, I've had the base plus 4 phones for about a
year and a half. Unreliable, searches for base, drops calls. I
originally loved this phone. I have a wireless network and have turned
it off to rule that out as the problem...still, same problem. Has
anyone tried replacing the battery?
I'm thinking about buying (after trying to see if Vtech will send some
for free first) more batteries but would like to know if anyone else
has had any luck with a new battery yet.
I have the same problem. Unreliable, searches for base, drops calls. I really like this phone as well. Did
anyone try replacing the battery? If so, did it work? I thought it might. thanks....
I have had this problem before with this V tech phone. It keeps saying it cannot find base then it drops the call. I called customer service and they went through some steps to troubleshoot over the phone but nothing worked. They had me mail my one phone and base to them in the original packaging and receipt and they sent me a refurbished one. It was a big hassle and I would never buy these phones again.
I only had the phone about 8 months. Now I have owned the phone for 1 1/2 years and I am having the same problem again. Ugghh. I need to run my business not worry about phone problems.
My system has worked great for about two years. Suddenly I wake up to all my phones beeping every 30 seconds or so. I checked the base unit and it has power and finds everything ( the remotes beep) then the whole base unit goes dead like the power plug was pulled and the the remotes beep again that they have lost the base. I was hoping that the transformer was intermittent and i was going to swap it out with one of the remote bases, but... they operate on 9VDC and the base uses 7VDC.... I'm trying to get a 7VDC to test otherwise it loks like its time to pay for another base. BTW I opened up the base unit to check the battery and it never had one. I'm sure it's not the problem, but were they supposed to come with a battery? there was not one in the box when I bought it.. Another Best Buy missing parts purchase [[[sigh]]]
my phone drops calls seconds after receving them, loses singnal with base
phone cannot find base
