Compaq Presario Laptop Logo
Dennis John Galindez Posted on Jun 09, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Vertical lines in my laptop screen
Hello! I've been using my Compaq Presario (M2223AP) Laptop for 2 years now, then all of a sudden I saw 2 vertical lines on the screen. 1 line is a clear red line (but not so thick & dark) located about 1/3 from the left of the screen while the other is a very faint (thin, almost transparent) line located about 1/5 from the right of the screen. I think it might be a monitor problem. I'm not very good in fixing computers so I have not done anything about it yet. I'd appreciate your help very much. Thanks!
  • Anonymous Dec 09, 2007
    vertical thin lines on hp lap top screen
Anonymous
Level 3:
  • Master 624 Answers
  • Posted on Jul 22, 2007
Anonymous
Master
Level 3:
Answers
624
Questions
Helped
675604
Points
1792
This appears to be a duplicate posting, see this link for the active post: http://www.fixya.com/support/t152864-vertical_lines_in_laptop_screen
Anonymous
Level 1:
  • Contributor 32 Answers
  • Posted on Jun 09, 2007
Anonymous
Contributor
Level 1:
Answers
32
Questions
Helped
76587
Points
59
You could try and download a new display driver from here http://h10025.www1.hp.com/ewfrf/wc/product?cc=mx&lc=en&dlc=es&product=499234 if that dosent help Id imagine it is the screen that is at fault.
5 Related Answers
Anonymous
  • 624 Answers
SOURCE: Vertical lines in my laptop screen BEWARE SPAM NUMBER +1-800-532-4187 BELOW
A VGA monitor is a monitor that uses a standard VGA connector to attach to your PC/laptop. A VGA connector is a small D shaped socket connector, about ½ inch long and ¼ inch wide. Its usually blue with three rows of holes (total of 15 holes) where pins from the mating connector match up with. The only other thing that may look like it is a serial port but that is easy to distinguish, it has two rows of pins for a total of 9. What 24 sever is suggesting you do is connect another monitor to see if the problem shows up there as well. I?ll be surprised if it does since usually this type of display problem on a laptop more often than not is due to a defective connection inside the laptop screen area. A quick test and perhaps even fix would be to grasp the right and left sides of your display while it is on (displaying the offensive lines) and gently twist like you were wringing out a towel. Again, and I emphasize, gently using only a couple of ounces of force. Watch to see if the lines disappear, get worse of make the screen flash or change. If you do then its likely cause is the connector from the LCD panel to the electronics has oxidation or a loose connection. If you?re lucky the flexing might even fix your problem, if not you will have to take it apart to find out exactly what is going on or take it to your local repair shop.
A
Anonymous
  • Posted on Dec 09, 2007
Sorry, but I find these sites difficult to figure out - I'm not a chat room person. I just wanted to thank dg9dotorg for the comments and whenever I finally find out the cause and get it repaired next year, I will advise what caused it. edierosa
A
Anonymous
  • Posted on Feb 13, 2008
That a great answer I'm just trying to figure out how to fix it. I have the same problem I hooked a external monitor on it works great. How do you fix tape carrier package ( TCP)?
A
Anonymous
  • Posted on Aug 17, 2008
myne has a green line also but i used to be able and tap it and it would go away after i did it a few times i got it again so i tried to compress it again but it wouldnt work :P
Anonymous
  • 169 Answers
  • Posted on Sep 29, 2008
I know not everyone has this ability, but if you can, go to a friend's house and hook up an external monitor to your laptop. You may need to use the function keys to switch from LCD to external, but if the lines go away on the external, you have a bad LCD. If the line shows up still on the external, then your problem is either:
a) video driver (free, easy fix)
b) bad inverter (video 'outputter') ...approximately $10-50/varies + labor costs to replace
c) bad video card/motherboard ...usually between $200-$400 + labor to replace
Hope this helps - please be sure to rate my answer :)
2answers
Have you tried hooking it up to an external monitor?
This would ensure that it's the screen and not the video card..
If you do that and you receive a good picture then it could be something as simple as a loose video cable. Or it could also mean something like a bad video card or the expensive one, a bad screen.
6helpful
I had the same problem - sent it in to Acer and they replaced the LCD for 500 bucks!
the lcd (liquid crystal display) is damaged at this time, nor the inverter, that is of course inside of your pc, im afraid you need to send this to a repair shop
cheers
if this line is there during boot up then it is a monitor problem usually. but if it is not then it is a problem with your windows files. you could try reinstalling your windows from the disks you were given with it? otherwise i will look into it. email me if you need more help. [email protected]
thanks
matt
My understanding is that you have 2 laptops with the same problem, if that is the case, you need to replace the lcd. When you have lines on lcd's, that is a sign of a bad lcd.
4helpful
There can be 3 possible reasons for this
1)Screen connector cable is loose. You can try to re-seat it and see if works.
2)display card problem. Connect your laptop to an external monitor and see if the problem persists. If it does not then
3)You will need to get a replacement LCD screen.
Hope this helps!
what i recommend you to test is to press behind your monitor and see that the line goes off or not.If it does..that mean you have a loose connection,it can be fix.Incase no then you have problem with your LCD.Normally if its LCD problem then you fix this problem,all you have to do is change the LCD.
goodluck,takecare.
thats monitor problem dude, better go to the nearest repair center of your toshiba to assist you bout this problem.
1helpful
2answers
Check it on External monitor prior to replacing the screen.. If the problems there as well its not the screen..
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
