Computer wont allow to do a restore
SOURCE: How do I factory restore
F11 will get you into the boot BIOS at computer restart
F10 will take you into System Recovery which does the trick by basically accessing an "XP CD" that was on a separate partition of the original hard drive. It's as if your using XP straight after an installation
Restart your computer, Press F10 on the keyboard and it should boot into the HP System Recovery .Now Remember this will wipe all files and load up factory-installed settings (drivers, programs, etc) and it will erase all of your pre-existing files. Please backup your files don't forget that
SOURCE: HP A620N DESKTOP WINDOWS XP RESET TO FACTORY SETTINGS
Restart your computer now as soon as you hit the power button keep on holding Alt key & keep on tapping F10 key Alt+F10 it will open the recovery console select full factory restore and follow on screen instruction this may vary depending on your computer and operating system (Note:this will erase all datas on the computer) or you might try Restart your computer during the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS using the arrow keys you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart You will also need to set the time and date hope it helps
SOURCE: need to know how to restore to factory settings
System
restore simply backs up your HP laptop to an earlier date when it was
functioning properly whereas the PC recovery feature actually backs up
your HP laptop to its original settings....http://comprehensive-support.blogspot.in/2012/06/reset-hp-laptop-without-restorerecovery.html
If the given guide doesn't work for you, get the reliable HP support at http://www.vtechsquad.com/hp-support/
Make copies of all things on your PC you want to save, such as photos, documents and other installed programs. Resetting your PC to factory settings will erase all data on the hard drive. It will erase anything that you installed on your computer after you received it.
Restart your computer.
As the computer is turning on, you will see a blue bar that says "Dell.com" across the top of your monitor. At this time, press the Ctrl and F11 keys simultaneously. If you wait too long, you will miss the opportunity to do this and will have to restart your computer again.
Click the "Restore" option when the next screen appears.
Click "Confirm." The PC will begin its resetting process. This process takes approximately 10 minutes.
Click "Finish" when the process is complete. Allow the PC to restart itself. Do not restart it yourself since it needs to run through its boot program.
Click "Yes" to allow the computer to restart. When it does, it will be at original settings, and you will see the "End User License Agreement" screen. Click "Next." The System Restore screen will appear, and the computer will do another restart.
Once it does another restart, click "OK." You have now reset your Dell desktop to factory settings.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
