Acer Aspire 5500 5570-2609 Laptop Logo
Posted on Jan 12, 2009
[email protected] change driver Mobile Intel R 965 Express Chipset Family from ACPI Uniprocessor pc
2helpful
COMPAL EAL51 barebone
Here you go:
1394
VIA OHCI Compliant IEEE 1394 Host Controller
BATTERY
Microsoft AC Adapter
Microsoft ACPI-Compliant Control Method Battery
COMPUTER
ACPI Uniprocessor PC
Diskdrive
Universal HDD
DISPLAY
Mobile Intel (R) 915GM/GMS, 910GML Express Chipset Family
HDC
Primary IDE Channel
Secondary IDE Channel
Intel (R) 82801FB/FBM Ultra ATA Storage Controllers - 266F
INFRARED
SMC IRCC - Fast Infrared Port
KEYBOARD
Keyboard 101/102 keys Microsoft Natural PS / 2 Keyboard
MEDIA
Audio codecs
Video Codecs
Midi Control devices
Legacy Video Capture Devices
Legacy audio drivers
Microsoft Kernel System Audio Device
WDM Audio Compatibility Driver Microsoft WinMM
Realtek AC'97 Audio
MOUSE
PS / 2 mouse
NET
1394 Adapter
Remote network engine Miniport (IP)
WAN Miniport (PPPOE)
Parallel Direct
IR
Realtek RTL8139 Family PCI Fast Ethernet NIC
WAN Miniport (L2TP)
WAN Miniport (PPTP)
OTHER DEVICES
PCI Modem
PCMCIA
Generic CardBus Controller
PROCESSOR
Intel Processor
SDHOST
SDA Standard Compliant SD Host Controller
SYSTEM
Generic Bus
Button ACPI resource sixed
Button tie / Untie ACPI
The system CMOS / real-time clock
Direct access memory controller
Programmable Interrupt Controller
Microcode update device
Microsoft System Management BIOS Driver
Software Device Enumerator Plug and Play
Logical Disk Manager
Manager volumes
Intel (R) 82801FB/FBM SMBus Controller - 266A
Intel (R) 82801FBM LPC Interface Controller - 2641
Intel (R) 82801 PCI Bridge - 2448
Microsoft ACPI-Compliant Embedded Controller
Microsoft ACPI-Compliant System
Microsoft Composite Battery
PCI bus
PCI standard host CPU bridge
ISAPNP port
Terminal Server Device Redirector
ACPI
Terminal Server Keyboard Driver
Terminal Server Mouse Driver
System Timer
UNKNOWN
PCI FLASH memory
USB
Intel (R) 82801FB/FBM USB2 Enhanced Host Controller - 265C
Intel (R) 82801FB/FBM USB Universal Host Controller - 2658
Intel (R) 82801FB/FBM USB Universal Host Controller - 2659
Intel (R) 82801FB/FBM USB Universal Host Controller - 265A
Intel (R) 82801FB/FBM USB Universal Host Controller - 265B
USB Root Hub
USB Root Hub
USB Root Hub
USB Root Hub
USB Root Hub
VOLUME
Generic volume
1helpful
Sir, my laptop is compaq c713tu and i had installed XP in tht. but i cant get the display driver. please help me out.
You can download "Mobile Intel 965 Express Chipset Family Video for XP" Graphics drivers from Intel Download Center
Hope it helps.
1helpful
Looking for drivers for moble intel(r) 965 express chipset family
Here si the link from where you can downalod the drivers
http://www.intel.com/support/chipsets/sb/CS-025753.htm
That's it.
3helpful
How can I change the resolution from 1280 x 800? This is the highest possible according to the display setttings. I have removed the generic pNp monitor. I am running Vista Business. The display adapter is...
Graphics Unable to use the native resolution, such as 1920x1080, 1680x1050 and 1440x900 circuit388.gif Symptom(s):
On some displays, users may be unable to use the native resolution when using Intel® chipset graphics. Resolutions such as 1920x1080, 1680x1050, and 1440x900 are not available in graphics properties.
Cause:
The display's EDID is not read properly when connected to some digital flat panel displays. Display devices describe its capabilities by sending EDID (Extended Display Information Data) to the computer.
Solution:
Intel has released a graphics driver to specifically address this issue; however, there may be side effects to this solution such as longer than normal resume times from standby. This solution will only work with external displays such as DFP displays connected to the computer's VGA port. This driver is not designed to address issues with a notebook's built-in display (Local Flat Panel) or with TV’s connected to the system. This driver is provided as is. Intel has not tested, and does not guarantee, the operation of the driver for this purpose.
For the desktop and Mobile Intel® 945 Express Chipset Families:
If you have a computer that has the Intel® 945G or 945GV Express Chipset or the Mobile Intel® 940GML, 943MGL, 945GM, or 945GMS Express Chipset, click here for drivers that resolve this issue.
For the Intel® 3 Series Express Chipset Families and the Mobile Intel® 965 Express Chipset Family:
If you have a computer that has the Intel® G31, G33, G35, Q33, Q35 Express Chipset or the Mobile Intel® 965 Express Chipset, click here for drivers that resolve this issue.
For the Intel® 4 Series Express Chipset Families:
If you have a computer that has the Intel® G41, G43, or G45 Express Chipset or the Mobile Intel® GL40, GM45, or GS45 Express Chipset, click here for drivers that resolve this issue.
For the desktop Intel® 946 and 965 Express Chipset Families:
If you have a computer that has the Intel® 946GZ, G965, Q963, or Q965 Express Chipset, click here for drivers that resolve this issue.
How to identify your Intel® graphics controller
How to install the graphics driver
I cannot select a larger display mode (resolution, refresh rate, or color settings). How do I resolve this issue?
Error: "The driver being installed is not validated for this computer..."
Operating System:
Windows XP Professional x64 Edition*, Windows Vista 64*, Windows Vista*, Windows Vista 32*, Windows 7*, Windows 7, 32-bit*, Windows 7, 64-bit*, Windows 7 Enterprise, 32-bit version*, Windows 7 Enterprise, 64-bit version*, Windows 7 Home Basic, 32-bit version*, Windows 7 Home Basic, 64-bit version*, Windows 7 Home Premium, 32-bit version*, Windows 7 Home Premium, 64-bit version*, Windows 7 Professional, 32-bit version*, Windows 7 Professional, 64-bit version*, Windows 7 Ultimate, 32-bit version*, Windows 7 Ultimate, 64-bit version*, Windows XP Professional*, Windows XP Home Edition*, Windows XP Tablet PC Edition*, Windows XP Media Center Edition*
This applies to: Intel® 3 Series Chipsets
Intel® 4 Series Chipset
Intel® 82945G Express Chipset
Intel® 82946GZ Graphics Controller
Intel® 82G965 Graphics and Memory Controller Hub (GMCH)
Intel® 82Q963 Graphics and Memory Controller Hub (GMCH)
Intel® 82Q965 Graphics and Memory Controller Hub (GMCH)
Intel® 945 Express Chipset Family
Intel® 946 Express Chipset Family
Intel® G31 Express Chipset
Intel® G33 Express Chipset
Intel® G35 Express Chipset
Intel® G41 Express Chipset
Intel® G43 Express Chipset
Intel® G45 Express Chipset
Intel® Q33 Express Chipset
Intel® Q35 Express Chipset
Intel® Q43 Express Chipset
Intel® Q45 Express Chipset
Mobile Intel® 4 Series Express Chipset Family
Mobile Intel® 945 Express Chipset Family
Mobile Intel® 945GM Express Chipset Family
1helpful
Download
you can download here
http://www.userdrivers.com/Notebook-Tablet-PC/Compaq-Presario-C700T-CTO-Notebook-PC-Mobile-Intel-965-Express-Chipset-Family-Video-Graphics-Driver-for-Windows-Vista-32-bit/
Graphics Driver for Presario C734TU in Windows XP your Thanks For Sound Driver
ur Graphic chipset is intel 965 Express family dont worry download this driver from intel direct it will work 100% pls rate me FIXYA for the help if u like
http://downloadmirror.intel.com/17354/a08/win2k_xp14371.zip
I want intel 965 express chipset family divers
use this link... http://downloadcenter.intel.com/default.aspx?iid=gg_work+home_dowloads
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
