SOURCE: Incoming Call not Ringing
Either call line 3 first, or make your phone ring :-)
What might be the easiest is to swap modular plugs in the back room between 2 and 5. That way, you get your old extension back and everything will work as it did.
If you can't do that, then you're going to have to do some system programming to turn on the ringing on your phone. If you have a TA series system, you should be able to do it from either the PC or a phone connected to jack $1. If you have another model, you should have a system manual on how do make programming changes.
Carl
SOURCE: I have PBX Tes824, Main phone kx-t7730 When it
to ring only at extension 101 and 106,you can do this press *# 1234# press 408 speaker phone CON. press * CO1. Enable press right arrow key from 7730 phone CO2. mixed CO3. mixed CO4. mixed CO5. mixed CO6. enable press Auto dial store thats it
SOURCE: MY EXTENSION DOESN'T RING FOR
JUST AS YOU'RE TOO LAZY TO USE THE SHIFT KEY AND LOSE THE CAPS LOCK KEY, I'M TOO LAZY TO LOOK UP THELINK TO A MANUAL. HOWEVER, I CAN TELL YOU THAT YOU COULD GO TO THE PROGRAMMING MANUAL FOR A PANASONIC KX-TD 816/1232 AND LOOK AT DIL 1:N PROGRAM 603 AND 604. IT'S WHERE YOU SET THE EXTENSIONS THAT RING WHEN A CALL COMES IN.
Carl
SOURCE: On the Panasonic KX-T7633, how
A couple of ways, the easiest is to dial *41103 on the intercom. *40 may also work, but it picks up any ringing outside line.
Carl
SOURCE: how to assign password for the extension not to make international calls
It's not a password, it's a restriction. You change the Class of Service for the phone and put in the international code as a restricted digit.
Check your Programming manual for the system.
Carl
