SOURCE: Oil for Comet pump
aftermarket oil will be fine just use same grade of oil,all manufacturers want that extra kick,
SOURCE: It will not dispense the soap.
You need to adjust the nozzle on the end of the lance so the machine will draw chemical at low pressure.
Testimonial: "Thanks for your help, I will give that a try."
SOURCE: what type of oil goes in a comet axd 3020 pressure
You should use what the pump manufacturer recommends. Typically a 30wt non-detergent (non foaming) oil. Do not over fill. If there is a sight glass half way is normal. Or if it has a dip stick follow the mark there.
Here is a great link for pressure washer parts and info
This link goes right to oil page:
http://pressure-washer-parts.com/shopdisplayproducts.asp?Search=Yes
