Could be any number of issues, try checking your ram first. Sometimes when the ram cards are either, broken, loose, or the latches arent properly connected the ram card wont complete the circuit and the screen will remain blank, if cards are attached properly them try taking one card out amd run it with only one card, then switch the cards and try again, remember to check the latches are all closed even on the empty slots.
it could also be you graphics card, check that you are connecting the screen to the output from the graphics card and not the onboard, it is an override to the onboard. If that fails try taking out the graphics card and runing output through the motherboards onboard.
This answer assumes basic knowledge of computer components and installation
Sounds like an overheated card but maybe it's just not inserted properly. Try to take the card out and insert it again with a bit more force. You will feel a click when the card is inserted properly. When I first inserted my xfx nvidia geforce 6200 agp I got proper image when booting but when windows was started I had a black screen. When I took another look at the card I saw the card was not properly inserted. A bit more force on the card and it said click. Now I have no problems.
Try removing the memory card of your cellphone and turn it on again. Your memory card maybe corrupted and causing your phone to not start. But if still nothing happens to your phone then the last option for it is to reprogram your phone. Turn off your phone and then press this keys altogether: * + 3 + green call key and then power on. Release the keys if the phone already showing the a settings to be set. Hope this could help you. Please don't forget to rate me..:-) Thanks..
Is there any type of flash/memory card inserted? Also how long have you owned the unit? Either try a different card or have the unit sent in for service. If you need further assistance let me know. Thank you, Lee
Onthe bottom of the legs, there is a thumb latch, press that all the way down into the hold it is in. do this on all three legs. Then once that is done turn the whole thing to the left, it should fold in two, on the sides, there are three latchs that go into the hole next to the small legs, those latches secure it in place..... The thumb laches can be hard just so you know
To unfold, simply press on the holding latches, and pull up
Hi, if your PC is a IBM ThinkPad, you can lift the keyboard by unlocking both latches on the side of the computer (The same latches you use to open the screen) and then lifting the board in the same way as the LCD screen. To access the memory you probably has to remove a sticker, some screws or even the Hard Disk Drive. Tell us what model of notebook you have.
Device cannot detect files on the memory card. Cause The memory card might be missing or inserted incorrectly.Verify that the memory card is inserted correctly.
The files might not be in the correct format.To
print from the device control panel, the files must be in the sRGB JPEG
format. To print other formats, you must use a software program on your
computer.
You might have inserted more than one memory card.Only one card slot can be occupied for the device to detect JPEG files. Verify that only one card is inserted.
