My lanier ld425c is showing offline all sudden and my computers are not connecting to print
Came in this morning and we had unplugged the copier, printer ect..wen plugged back in to use..it would print anything...i turned it off..then back on still wouldn't, I used a usb wire and plugged in to computer, then it printed...I started looking at the other computers and its all the sudden says offline, so my computers arent connecting to the wireless....i go into the copier and push printer button and make sure the online is lit up under that part and it is..it doesn't show offline..i took the printer out of my laptop and tried to put back in my searching for wireless printer in the office and it doesn't find it..where normally pops right up and is very easy install...Im at a loss!
5 Related Answers
Anonymous
  • 8 Answers
  • Posted on Feb 21, 2008
SOURCE: D-Link Print Server Compatibility issues
DP-300U Print Server is not compatible with Sharp AR-5320. Pls check D-Link website on the list of compatible printer. For USB Print Server that is compatible with Sharp AR-5320 try Intellinet.
Anonymous
  • 234 Answers
  • Posted on Sep 28, 2008
SOURCE: Printer keeps saying insert memory card
The message is not an error message and does not indicate an issue with the product. The message is designed to be an invitation to print photos from a memory card. Follow these steps to insert a memory card into the product. For more information please check the link bellow: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01436439&cc=us&lc=en&dlc=en&product=3194498 Good Luck
Anonymous
  • Posted on Oct 09, 2008
SOURCE: Brother mfc 665cw connection error
I have a MFC665CW connected wirelessly to a router and a pc connected by ethernet to the router, with a broadband satellite receiver connected to the WAN port of the router (plan to add another PC to the network soon, so have set up the network in advance). I had trouble with the brother status montior flashing 'Ready' then 'Offline' all the time, when I knew the printer was always connected to the network. I had set up the DHCP stuff on the router to allocate IP addresses to everything that connects to the network, like you are supposed to. I updated drivers and firmware, but the problem continued.
When I checked the router status log I saw that one MAC address in the network was making a DHCP request every 5 minutes (i.e. it was asking the router to allocate it an IP address at regular intervals). Every time the router answered that request it made the Brother status monitor go 'offline'. The MAC address was my broadband modem. I fixed the issue by setting the router to allocate a static IP address to the MAC id for my broadband modem (in the DHCP setup section in the router's admin interface). That stopped the dynamic IP address requests from the broadband modem and the Brother status monitor works fine now. I also set static IP adresses for the printer and PC to be on the safe side, although I don't think that matters.
So, check your network log and look for a MAC id that makes regular DHCP requests and then set a static IP address for it. Hope this helps you guys too.
Anonymous
  • 115 Answers
  • Posted on Oct 25, 2008
SOURCE: printer busy/or error
Sounds like your machine is using DHCP, not a static IP address?
Print your network settings from the Printer, then try to Ping from a computer on the network.
Check the Network setting of the machine, make sure it is set to a fixed (static) IP Address.
If this is the problem, you can go into your PC printers port and change the port to the reassigned IP Address of the machine.
If you reinstall the drivers then you will have this installed twice, one will work one will not, so delete it from the printers folder before you reinstall before you reinstall
Anonymous
  • 4 Answers
  • Posted on Feb 17, 2009
SOURCE: HP Photosmart Printer, Mac won't recognize with USB
Sounds like their is not communications between your printer and computer. Could be a bad USB cable - swap out and see if that fixes it. If not it could be a faulty USB port on the computer or printer. You can check the computer USB port by connecting another device, but there is no way to check the HP's USB port. I would also check printer USB port for dust bunnies! If you're not able to resolve, I think it is time for another printer.
Where can I buy new drums for Lanier MP LD425c
the problem is the model number mp ld425c
from researching you need to search on mp c2500 replacement drum
or
see
https://discountcopiercenter.com/ricoh-aficio-mp-c2500-drum-units/
suggest contacting the above company to see if lanier was taken over by ricoh
as this sometimes happens and the ricoh part may suit your printer
How to print enevelopes without them jamming in a lanier ld425c
in bypass put envelopes in short edge first, push the # button, select size of envelopes and OK it, (needs to be told of size)-Carl
Why after we change the toner it will not print
after refill the toner may be bias charging roler is not proper fiting
or toner cartridge is not proper insert
Lanier LD425c touch screen does not function
You can try to adjust the touch screen > press the yellow clear button then 1993 & press the stop button three times & follow the display screen. Odds are you are going to have to replace the touch screen, the adjustment will not last long....Good Luck
2helpful
Why am I getting lines on my prints when I go thru the top feed of my Lanier LD425C?
Clean the **** glass. It is a long skinny glass to the left of the big rectangular glass under the feeder. Clean it and your problem should go away.
1helpful
I have a lanier ld425c that i purchased after a company went out of business. the copier turns on andcopies fine. the control panel touch screen does not work. any suggestions
Hello!
I am not 100% sure but i think you can calibrate your touch panel.
Follow this steps:
- Press yellow key.
- On the key pad press 1999.
- Press Red Key five times.
After that you will see the option to calibrate your panel. You just need to follow the wizard.
If you have any dought reply to me.
See you!
The printer will not print. it shows that it is offline. i went to the "services" menu and restarted the printer spooler and the printer went to ready but it wouldn't print and then went back to offline....
First thing to do here is to unplug the printer from the computer and restart the computer , then once the computer is already back that's the time you connect the printer back and lets see if the printer will be detected by the computer, if still not and printer is still showing offline, better go to control panel and gp to printers and faxes and click on add and follow the wizard to install a ewn printer that should correct the problem.....
9helpful
Service code 561 error
Hello sir; Just follow my direction, it will reset your machine;
1, press "clear mode", "107", then press and hold down "clear/stop" key.
2, touch "copier SP" on the screen.
3, enter "5810-001" press enter.
4, set value to 0, then turn power off and back on again.
Top Lanier Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
