Perfectly OK until this week end, Garaged it SUNDAY NIGHT, mODAY MORNING , WOULDN'T START . put battery on charge - started OK but noticed front fog lights were on, switch not operating. All other lights etc working OK. Any suggestions?
SOURCE: 2005 pt cruiser wont start
First check to make sure all the harness plugs on the PCM are pushed in and tight. It happened to me.
Then check your grounds.
And you need to get that multi switch replaced to fix that fog light problem. Just remember to take the relay off of the old one and replace it on the new one.
SOURCE: Cadillac Seville with new battery won't start, won't even fire up!!
Could be your alternator. If you can get it started again. Try to have the alternator checked out.
SOURCE: 2003 4 cyl Camry 90,000 miles Headlights, dash
yes sounds like youre starter motor or maybe try and shift it to nuetral may b e neutral safety switch gone bad
SOURCE: Front fog lights do not come on. Worked fine
there is a relay for them.are you sure is not bulb.
