Cant set digital and analogue time to match.says par in left digital and lon in right hence times are 1 hour different. lost manual and cant seem to find a download of one thanks in advance
Try this link below
http://www.citizenwatch.com/en-uk/support/setting-instructions/
SOURCE: casio telememo 30 syncronising analogue and digital time
To set the analog time to match the digital time...
There are 4 buttons: top left=A, top right=B, lower left=C, lower right=D
Get the watch in timekeeping mode (where it shows the digital time or date)
Press C six (6) times
Hold down A until the current digital time begins to flash
Press D repeatedly to advance the analog time, one minute at a time.
If you need to advance the analog time at high speed, HOLD D DOWN.
To return to regular timekeeping mode, press C
Set the digital time so that it matches the analog time, since you can reset the seconds easily.
SOURCE: lost instructions to set my solo digital watch
I think I have the same watch and was just looking here to see if I could find how to stop the alarm going off every hour! However, I think I do know how to change the time: press the mode button three times (the first one brings up something like the stopwatch, the second brings up what may be an alarm time). On the third press you should get the time appearuing with the seconds flashing on the far right of the display. You can then change the second by pressing the"start" button. To change the minutes or hours, oress the "reset" button until they start flashing and use the start button again. pressing the reset button again will bring up the date to change. keep pressing until nothing is flashing any more and poress mode and it should bring you back to the current time. hope you can follow this and it works!
SOURCE: Setting time on Watch
go to this website follow the instructions for finding your particular watch module located on the back of your watch and enter it in the space provided. This will lead you to a place where you can download your manual and learn how to set your particular watch. here is the link to follow and please leave feed back if it was helpful. http://world.casio.com/wat/download/en/manual/
SOURCE: how to set up ladies roxy digital watch
I found users instructions on roxy website at:
http://www.roxy.com/search/index.jsp?f=Taxonomy%2FROXY%2F2818169&categoryId=2818071&f=Taxonomy%2FROXY%2F2818071&fbc=1&fbn=Taxonomy|Watches&fbx=0
We were able to program our watch completely!!!
If you look on the back of the watch that you bought on the metal plate, it tells you the style. Ours was the Roxy 70's digital watch, and I found specific instructions at (even if this is not your style, the instructions may work):
http://www.roxy.com/graphics/uc/roxy/manuals/Roxy_manual_watch_70s.pdf
SOURCE: i cant set analogue time on casio hd wrist
Follow this link:
Rate, please.
