I got a same problem with above mention; "What i will gonna do to make my Eurostar epad 5, it got lock because of too many pattern attemps. My problem is my epad now has no internet connection so i cannot unlock it using my google account. I do reset but still asking my Username and Password, What i will gona do now? Please help. I have a Eurostar Epad 5
SOURCE: i attempted my unlock pattern to many time now my phone is locked
you will have to do a master reset....you will loose everything on the phone....it is important that you create a google profile, which will back up all your contacts....
if this doesnt work is because your phone doesnt have the harware keys firmware update... need to take it to a repair center and have do a software reflash
SOURCE: locked out by too many
1. On the computer: Start PC Companion™.
2. On thecomputer: In the Support Zone™ descriptor, in the Software Updatesection click Start > (Repair) and follow the instructions on the PCmonitor screen.
3. Turn off the phone.
4. Connect the USB cable to your computer.
5. On the phone: Press and hold down Back key and connect the USB cable to the phone.
6. Follow the instructions on the screen.
Note : The software in your phone will be replaced. All personal data stored in your phone will be lost.
There is also a way to unlock the pattern screen lock by signing in with your Google account.
1. After 30 seconds, tap Forgot pattern?
2. You need to log in with the primary gmail.com e-mail address and not the alternative email address connected to the Google account.
3. Tap the username field and enter the primary Google account user name.
4. Tap the password field and enter the primary Google account password.
5. Draw a new unlock pattern and tap Continue .
6. Draw the new unlock pattern again and tap Continue .
If these options are not available to you, please describe preciselywhat you see when attempting to connect to your PC and use PCCompanion.
SOURCE: My daughter has an LG Touch GW620 phone and has
give it to lg service center and re-install ur os again.. simple
SOURCE: I locked my Kyocera Zio
Hi ashleysmi298 go on your computer and sign in to google. Under settings go to forgot password. You need to get you gmail password. If you don't remember the only other way is to do a hard reset on the phone. But here is the bad news , You will lost all your information and settings apps and whatever else you have on the phone, Now by going to google you can get your password and user name back. If that doesn't work you will need to powwer the phone off. hold the power and the up and down voule button at the same time. You do this until t comes on the screen.Now make sure you take out your memory card . If you don't want to do any of this go to your local carrier and have them help you with the hard reset.
I’m happy to help further over the phone at https://www.6ya.com/expert/ronald_e152e07e272e4f27
SOURCE: Hi, I need help, I have SAMSUNG Galuxy S (I9000),
Do this but make sure you may wan't to lose files:
1. Turn off the i9000 phone or take out the battery and reinsert it.
2. Hold the Volume Down button
3. Press and release the Power button
4. Select Clear Storage by pressing the Volume Down button
5. Press and release the Power button
6. Press Volume Up to confirm i9000 MATER RESET
Done!
