Have had lots of problems with brakes,rotors turned and 1 replaced ,brake shoes,brakes and everything else and now a clicking noise ,Just had the transmission shifter replaced because dealer ship said that was the clicking noise,but $ 500.00 later still clicking noise.Is my car a LEMON??????
SOURCE: 2006 lincoln town car
Did the dealer clear the codes last time you were in. they have to be cleared
SOURCE: 1998 Lincoln Town Car: No turn signals, 4 way flash, brake lights
If only your brake light in middle of rear window works then your other bulbs are bad. If brake lights all work in the back than bulbs are good. If you put turn signal on right or left and the bulbs light in front and back then you need to change multifunction light control box under dash. My understanding is it cost $600 new. So I would try used.
SOURCE: traction conrtol , abs brake lights lincoln ls 2000
it might be a loose abs cable behind one of the brakes?
THANKS,i WILL PASS THIS ON TO THE FORD PLACE!,
i HAVE A MEETING WITH SHOP FOREMAN NEXT WEEK TO SEE IF THEY CAN FIND OUT WHAT IS GOING ON,THIS IS AABOUT THE 6TH TIME IN 3 MONTHS i HAVE HAD MY CAR IN FOR BRAKES,CLICKING OR GRINDING OR SOME NOISE,i AM BEGINNING TO THINK i HAVE A LEMON.
