Computer shuts down all programs and shuts down at random times or it was stay and randomly go off. No indication of it powering down. I have check hard drive, power supply, tried different memory, change the thermal paste on the processor and nothing works. What could be the problem what am I missing out
SOURCE: dell d410 laptop won't charge battery charger doesn't like the ba
There's a problem with the motherboard.
I would say try a bios update, but I believe it requires both battery and power adapter to be present before it will flash the rom.
The above probably won't work but it's always good to try the easy stuff first.
More than likely you'll just have to replace the board.
If you have any more questions, feel free to ask.
SOURCE: My Dell Inspiron 1525 has no power. Tried a
Make sure that there is a green light on the ac adapter. Try checking the end of the cable of the ac adapter and see if it is damaged ( the metal piece that connects into the laptop ). Also check the port on the laptop where you connect the cable of the ac adapter. If that is damaged then you have to request replacment of the motherboard if your laptop is still in warranty.
SOURCE: Dell Studio laptop shuts down randomly. Tried
your fan in your computer maybe shot or it might be set on hibernation mode
