I have a Fujitsu Stylistic 3500 which I successfully loaded XP Tablet Edition on. I installed the Pen drivers and it recognizes the pen, but it is not calibrated. The cursor is in the correct position in the middle of the screen, but as you move up the screen the cursor goes further away from the actual pen position. How do I fix/calibrate this?
Well there is a few ways to try to fix it first with a usb mouse check that the resolution is at it's native pixel count. This can be found on the manufacture website. If it is already at that resolution ensure that the CIC XPen drivers are installed. Those should have placed a recalibration program in the control panel. If those both fail, try uninstalling the drivers and restarting, then reloading the drivers. Hope this helps! food luck and godspeed!
SOURCE: pen not detected on especific zones of display
Had the same problem. Just open the tablets screen enclosure. Look at the back of the LCD panel. You will see a little circuit board with several black plastic connectors. Push all these connectors firmly to the PCD. You will notice that one or more have come a bit loose. Before closing the lcd panel housing, put some adhesive tape over the connectors. This will prevent them from failing again.
"OS" are: XP, Vista, and Windows 7
Select the [Drivers] you need from the "List."
"Download the Drivers."
!"Take a moment to rate the help."
Thanks paul7of9
Click here: http://support.fujitsupc.com/CS/Portal/driverdownload.do
