I have change power supply, T con board and y main board but it remain on standby only when I take take out power supply cable from y main board it swicth on and a T con board blink continueasly and can change channels and get sound but no picture
You reports that you've changed the T'Con board. Where is the T'Con board to a Plasma TV? There is no such board to any plasmas. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there or make a search by typing in the brand name of the device in the "Search Box", at the top right of the display window
SOURCE: Samsung 46" LCD TV stops responding
Ok, There are well three boards in this set that would influence such a
behavior. The culprit is the Key Pad Board. It has what is called a
leaky switch. This then locks up the Microprocessor. This will result
in the set operating like a ghost has the remote.
best regards
CircuitCity
SOURCE: TV HAS NO PICTURE...Need HELP!
your logic board is bad replace it and you should be fine unless your panel went bad i can walk u through to find out requirs volt meter
SOURCE: got a new T-con but no luck
is your back light constantly on when you are not changing channels.if so replace the main board. can you see a menu if you hit the menu button ? that is generated by your main board..... replacing the t-con will only correct vertical lines in the pic.
SOURCE: power supply is good but indicator lit just blink
i had a similar problem and I thought I had fixed the power supply but still didnt work. long story short I ended up replacing the power supply and finally worked.
good luck
I bought this Main Logic CTRL Board thinking is the same as T-con board BN96-12172A is the one which got a blinking light when the TV is on
Y main board and the power supply I have change
When everything is connected only blink once to Main Logic CTRL board and red light stays on the is no no change even if you press the power on button
