Logitech Webcam Logo
Posted on Jan 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error message when opening quick cam
Quick cam 10 exe has generated errors and will be closed by windows, Restart program.
I have run the program 5 times, same error message. can you help
DEKR
Level 3:
Genius:
  • Logitech Master 1,102 Answers
  • Posted on Jan 12, 2009
DEKR
Logitech Master
Level 3:
Genius:
Answers
1102
Questions
0
Helped
313069
Points
2384
You need to uninstall your camera
restart and then reinstall the cam.
This should help
Can't Uninstall W-XP
run msconfig and restor your computer to a date befor you moved the pc
good luck!
Problem is with iTunes
hi try this: The intention is to remove all iTunes and Quicktime software references. The following steps remove the software traces and worked on my machine. 1. Using add/remove programs uninstall Quicktime (click on Start ?> Settings ?> Control Panel ?> Add/Remove Programs) 2. Using add/remove programs uninstall iTunes 3. Right click on My Computer, use Search and remove all programs named Quicktime 4. Right click on My Computer, use Search and remove all programs named iTunes (except your iTunes download, so you won?t have to sit through another long download session). 5. Left click on Start, click Run, type ?regedit?, go to HKEY_LOCAL_MACHINE, click on SOFTWARE, and remove the Apple Programs folder (you may want to check in case you have other Apple applications, but all I had were iTunes and Quicktime in my Apple folder). Steps 1 through 5 should remove all traces of the software and now you can install iTunes. make sure you install all the latest updates from apple hope this will work for you :)
(Error code: 0xE000003D) IN ONE NOTE
hey, you may follow the below steps:
Steps to Fix/Resolve/troubleshoot the error code 0xE000003D:
1 - Repair your Office app
Error Code 0xE000003D will be fixed when Office repair tool replaces all the corrupted system files. Follow the steps below to run repair tool to fix the error.
  1. Open Control Panel using Start.
  2. Click on Programs and select Programs and Features.
  3. Click on the Office product that you want to repair.
  4. Click Change.
  5. Select Quick Repair and click on Repair. If Quick Repair didn't fix the Error Code 0xE000003D, select Online Repair and click on Repair.
Note: If Office Repair did not fix this error code, then remove and reinstall the Office installation to fix this Error Code 0xE000003D.
2 - Steps to remove Office
In case if the error persists even after running Office repair tool, uninstall Office from your computer.
  1. Click on Programs and select Programs and Features.
  2. Select Office Suite and click on Remove.
Note: If Office installation failed or it didn't fix the error, a manual installation is required to completely remove the Office Suite.
3 - Steps to remove Office manually to fix the Error Code 0xE000003D
If the error code 0xE000003D is re-occurring, proceed with the following steps to manually remove Office program from your computer.
Step 1: Remove the Windows Installer packages
  1. Find the Office 16 installation folder, typically located in C:\Program Files\.
  2. Right-click the Microsoft Office 16 folder and select Delete.
Step 2: Remove the Office scheduled tasks
  1. Open a Command Prompt window as an administrator.
  2. At the command prompt, type the following commands and press Enter after each one:
schtasks.exe /delete /tn "\Microsoft\Office\Office Automatic Updates"
schtasks.exe /delete /tn "\Microsoft\Office\Office Subscription Maintenance"
schtasks.exe /delete /tn "\Microsoft\Office\Office Click To Run Service Monitor"
Step 3: Use Task Manager to end the Click-to-Run tasks
  1. Open Task Manager.
  2. Click the Process tab
  3. If the following processes are running, right-click each one, and then click End task after you select each process.
  • .exe
  • setup*.exe
Step 4: Delete the Office files
  1. Press Windows logo key + R to open the Run dialog box.
  2. In the Open box, type %ProgramFiles%, and then click OK.
  3. Delete the "Microsoft Office 16" folder.
  4. Delete the "Microsoft Office" folder.
  5. Open the Run dialog box, type %ProgramFiles(x86)%, and then click OK.
  6. Delete the "Microsoft Office" folder.
Step 5: Delete the Office registry sub keys
  1. Open Registry Editor.
  2. Delete the following registry sub keys:
  • HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Office\ClickToRun
  • HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\AppVISV
  • HKEY_CURRENT_USER\Software\Microsoft\Office
  • Then Delete the Office key.
Step 6: Delete the Start menu shortcuts
  2. Type %ALLUSERSPROFILE%\Microsoft\Windows\Start Menu\Programs, and then press Enter.
  3. Delete the "Microsoft Office 2016 Tools" folder.
4 - Download and install Office
1. Sign in to your My Account page using the link https://go.microsoft.com/fwlink/p/?LinkId=613327
2. Choose Install.
3. Click Run or the equivalent depending on the browser you're using.
4. When you see "You're good to go", click All done.
Error Code 0xE000003D for Microsoft Office Outlook and Windows Updates
Cant download skype, problem with toolbar, error 2738
Take a look in Event Viewer I looked in Event Viewer to find out what MSI-file that generated the error message and found:
Log Name: Application
Source: MsiInstaller
Date: 23.09.2010 21:58:26
Event ID: 1040
Description:
Beginning a Windows Installer transaction: C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}\SkypeToolbars.msi. Client Process Id: 6564.
2. Running MSIEXEC with logging options I started a "Command Promt" and used the command: "cd C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}" to navigate into the folder containing the MSI-file.
Now using the command: "msiexec /i SkypeToolbars.msi /lv log.txt" (msiexec options: /i = Install, /lv = Log + Verbose output).
After clicking away the error message I just wrote "log.txt" in my "Command Promt" to open the log-file. Near the bottom of the log-file I found this line:
DEBUG: Error 2738: Could not access VBScript runtime for custom action
3. DEBUG: Error 2738 After a quick search at Google I found out this error indicates that the VBScript engine is not registered on the computer.
The solution for a Windows Vista or Windows 7 32bit:
- Click Start -> All Programs -> Accessories
- Right click "Command Promt" and click on "Run as administrator"
- Write "cd %windir%\system32" and hit Enter
- Write "regsvr32.exe vbscript.dll" and hit Enter
- You should now get a message that says: "DllRegisterServer in vbscript.dll succeeded."
- Click "OK"
The solution for a Windows Vista or Windows 7 64bit:
- Write "cd %windir%\syswow64" and hit Enter
- Click "OK"
4. Try again... Now I tried once more to run "msiexec /i SkypeToolbars.msi /lv log.txt" (I kept the /lv log.txt option to look for changes if the installer would fail again).
If you still get the same Error than continue to step 5.
5. Cleanup registry first, then re-reg My installation still gave me the same error, so after some more searching and reading on Google I found a solution that explained what I tried before (with the regsvr32.exe) and also an alternative step if that one should fail. The alternative step was to remove the Registry Key pointing to vbscript.dll.
The alternative solution for a Windows Vista or Windows 7 32bit is then:
- Write "reg delete "HKCU\SOFTWARE\Classes\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
- Click "OK"
The alternative solution for a Windows Vista or Windows 7 64bit:
- Write "reg delete "HKCU\SOFTWARE\Classes\Wow6432Node\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
- Write "cd %windir%\ syswow64" and hit Enter
- Click "OK"
Now using the command "msiexec /i SkypeToolbars.msi /lv log.txt" the installer started perfectly, ran all the way thru and Finished.
Conclusion This message indicates that VBScript engine is not currently registered on the Computer running the installer.
Vbscript.dll must get registered to solve the problem.
Ref: http://community.spiceworks.com/how_to/show/1577
23helpful
2answers
I have a Dell Inspiron 6000 with windows XP, McAfee Security Suite, and a Verizon USB for internet. When I turn it on I get an error message: dlbcserv.exe has encountered a problem and needs to close. ...
This error message is a result of your Dell printer software functioning improperly.
This is a 'quick fix' to get rid of the error message:
  1. click 'Start'->'All Programs'->Startup
  2. Right click on dlbcserv.exe and click 'delete'
PS: dlbcserv.exe is a Windows process installed alongside Dell Photo Printers and provides additional configuration options for these devices. Although it is not an essential process for the operating system, you should not remove & uninstall it unless it is causing serious problems and errors.Dlbcserv.exe is a Windows file created by Dell. The file is usually found in Program Files\Dell Photo Printer 720\dlbcserv.exe folder. If you find it anywhere else, Please note that dlbcserv.exe could be a virus, trojan, worm, or spyware. Scan your computer with an antivirus software to make sure it is not infected.
1helpful
When trying to open itunes from desktop the following error message is recvd: "Quick Time failed to initialize (error-2096) Quick Time is required to run iTunes. Please uninstall then re-install iTunes"...
Go to...
My Computer
C:\
Program Files
Quicktime
On Quicktime.exe
right click and select propities
Un- select read-only.
Click OK
Go back into Program Files
Go to iTunes Folder
Go to iTunes.exe
Select properties
Go on the compatability tab and de-select all.
2answers
Quickbooks won't open
How we can Fix QuickBooks Stopped Working
1. Use of QuickBooks Repair Tools
  • Download QuickBooks Repair Tools
  • Save the file in a local folder in the desktop
  • Shut down all the existing open programs and install these tools
  • It takes 20 minutes to run a scan in the whole device
  • After the tool has repaired the program restart console.
You can visit us for more information
https://www.xactons.com/quickbooks-phone-number/
Using Logitech WebCam - have sound but no picture
This is one of the known issues in this release.
You have to until the manufacturer released the patch or the updated version of the software with the fix.
And as you said, you can use the oldr version of the software until they have the patch.
You can see here under Known issues and expected behavior :
http://tinyurl.com/6xyrpd
Or
Try this :
http://tinyurl.com/6rxv8x
Or
http://tinyurl.com/5jq5zv
Or
Go back to the previous version.
Good Luck.
Live, Love, Laugh.
2answers
ITunes and Quick Time will not load and work together
well you have to re-install your windows on your pc...
or try re-installing the software of QUICK TIME 6.0.
it's the best i have used...
reply soon..
1helpful
update your anti-virus program, it's quite apparent that your system has been infected with a trojan.
Top Logitech Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
