I have had the printer for about a year and it just started printing backwards. Any solutions?I have had the printer for about a year and it just started printing backwards. Any solutions?
You can't post conmments that contain an email address.
Issue
After downloading and installing Windows XP Service Pack 3 on the computer, the HP product prints text and images backwards or as a mirror image of what appears on-screen when printing from any program.
Solution
To resolve the issue, turn off mirror imaging in Printer Preferences . To do this, use the following steps:
From the Windows taskbar, click Start and then click Control Panel .
If your computer is in category view, click Printers and Other Hardware , and then click Printers and Faxes . If your computer is in classic view, click Printers and Faxes .
Right-click the HP product from the list of printers, and then select Properties . The Properties dialog box displays.
From the General tab, click Printing Preferences . The Printing Preferences dialog box displays.
Click the Advanced tab.
Under Printer Features , click Mirror Image , click the down arrow to the right of the field, and then click Off .
This is actually a setting in the printer driver in that particular Dell laptop.
In the laptop in question, go to"Start" -> "Control Panel" -> "Printers"
Here right click on your printer and select "Printing Preferences".
Go to the "Finishing" tab.
On teh bottom right, you'll see an option called "Mirror Image".
Make sure that is "unchecked".
Click "OK". and the setting now have been updated.
Cheers,
Ed
to get to the root cause of the problem . you can try printing from the notepad and check it prints fine from the notepad . if it prints fyn then there can be some issues with the software compatibility.. which version you have for microsoft office.
The mirror image setting is in the printer properties/ printing preferences. You can either go to control panel/printers/properties, or when you press print, and the window pops up, in printing preferences you can choose the mirror image setting.
It's likely that you have an old outdated printer driver for your L7590 as this has been a long "known" issue with the L7000 series of MFD's.
To resolve the issue properly you need to uninstall the current driver version and then download the latest version of the software that isn't just driver/basic based.
You can extract the source files including the drivers folder using 7zip if you want to try and avoid installing all the additional bloat that comes with these printers.
Failing that, you need to define alternative quick settings to take over from duplex (two-sided) printing as this appears to have been incorrectly set to use mirror printing. Other quick settings have been implicated as well but the driver update should resolve all of them.
In some instances the driver update doesn't apply properly so you may need to uninstall and reinstall more than once... Remember to delete your printer from the printer listings and unplug it from the USB cable before you uninstall and reinstall to get it to work properly.
thats becoz the mirror image as be enabled on the printing preferances of the printer settings.
go to the printer icon under printer and faxes, turn off the mirror image,,,,,,,,,,,
For the port name, enter the share of your printer on the remote computer. For example, if your computer name is superDesktop and the printer share name is megaPrinter, you'd type in \\superDesktop\megaPrinter.
Finish the wizard and you're done, printing normally!
