Question about HP Pavilion dv9000z Notebook
Mouse pad on laptop not working
Mouse does not respond to touch
SOURCE:
Pyrhyc
  • 2028 Answers
SOURCE: touch pad driver.
Uninstall the driver from the device manager, then reboot. The machine will find the touch pad and reinstall the drive automatically. If this doesn't work, check the touch pad connection, they will sometimes work loose ar get a little dirt/corrosion build up. The connection is under the keyboard. At this point, if it's still not working, then it has failed and will need replaced.
Posted on Jul 20, 2008
Fixe_You
  • 1800 Answers
SOURCE: left mouse button on touch pad not working
have u tried to check it on the control panel/mouse options.
if its not working though i guess the have reason about that.
Posted on Dec 30, 2008
gsage
  • 180 Answers
SOURCE: my keyboard and touch pad isnt working...
If your operating system is Xp / vista reimage your unit by hit F11 on started up & Hp splash screen - select advanced - select full destructive recovery - you have corrupted your device controler for human interface devices - like your k/board & mouse - there is no way to reinstall the required dll's so full recovery is required.
Posted on Mar 08, 2009
  • 4 Answers
SOURCE: Touch pad on my dv9700 not working
simpletext and mbordolenco are both right. the wires come loose on my hp dv6000 sometimes and I have to disassemble mine sometimes
Posted on May 30, 2009
SOURCE: My Hp laptop - the touch pad will not work. I can
try going through control panel and then enabling the tap. see how that works for u
Posted on Nov 22, 2009
Touch pad don't work at all
after windows? start press and hold the Fn button and then press one the F7 button.
if not work, try to conect an external mouse and let me know if is being working.
Apr 07, 2015 | Computers & Internet
Sony vaio AR51E mouse cursor doers not move as touch pad not respoNding, EXTERNAL usb mouse works fine any ideas??
Go to Control Panel
SEE mouse icon... OPEN this
see if the touch pad is disabled
Try to go to the site Sony VAIO model specofic download latest driver for the touch pad
there are specific setting to enable the pad somehate it some love it but you can sort it out by looking at Control Panel /device manager etc
if USB mouse is working at least you can navigate to find issue
Jun 11, 2010 | Sony VAIO VGN-AR720E/B Notebook
My touchpad mouse won't work. it does not respond
If you are using XP, check your mouse settings under Control Panel. Make sure that your Touch Pad is enabled. If it is but it still won't work, have a mouse plugged into a USB port that will work correctly. Then download the latest driver from the Acer site for your touchpad. Uninstall the driver that is currently being used by your system. Then install the updated driver that you downloaded. This should allow you to use your Touch Pad. If not, you may have to take your laptop in for servicing.
Jul 15, 2009 | Acer Aspire One PC Notebook
Netbook touch pad quit working after attaching a USB mouse
Go into the mouse options in the control panel and make sure that the touch pad is not disabled.
May 31, 2009 | ASUS Eee PC 900 Notebook
Mouse is not responding at all
you need to go to device manager...
right click "my Computer"
select "manage"
select "device manager"
click the + sign for "mice and other pointing devices"
select your touch pad...
try to enable it or find what is wrong from there
You'll need a USB mouse or something of that ilk to do it.
good luck
Apr 10, 2009 | Lenovo 3000 N500 Notebook
Its starts in safe mode,and the touch pad wont respond
the touch pad could have simply failed, most OS will interpret the mouse pad as a mouse to make it work, so if its gone its most likely not working, I mouse attached to a usb or one of the ps 2 connections might give you a mouse back temp you can replace most mouse pads.
hope this helps
Apr 07, 2009 | Acer Extensa 5420-5687 Notebook
Touchpad is not working
You didn't mention an OS but the following is for Windows:
You may want to reinstall the touchpad driver for your unit. You may also want to check whether the touchpad is enabled under the mouse settings. Good luck!
Feb 24, 2009 | ASUS Computers & Internet
Lapptop touch pad not responsive
there is an option to enable/diable touch pad by clicking combination of fun+f5 or f6 or enable it from setup.
Oct 21, 2008 | Computers & Internet
HP Pavilion dv9000z Notebook Logo
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
