No lighted display on factory radio. Can tune stations with knob or steering wheel control.
SOURCE: Steering wheel lamps do not work (radio controls, temp, cruise)
The lights on the steering wheel are in the switches. To fix the lights, the whole switch needs to be replaced. Same thing goes for the Tempature Controls and radio. Overall, I think it would be very expensive to replace all of the switches to get the lights working. I have the same vehicle, and almost all of the lights are out.
I think the lights behind the gage controls are replaceable, although you still have to rip out most of the dash to get to them.
I have the auto-sense wipers, so I was leaving the wipers on all the time, and the would only work when needed. The bad part I finally found out about this was that while the wiper switch is on (even though they were not wiping), it caused all of the dash lights, switch lights and rear parking light to be on. I think this alone significantly cut down on the life of the bulb.
For now, I am just living without the lights. The temperature control is very expensive (just the part alone).
You can usually find the best price for these things at http://www.rockauto.com
SOURCE: how to set clock on 94 buick lesabre
Setting the clock is easy. Place the key in the ignition and place in accessory. The clock should come on. Push the set button, on the right side, and use the scan/seek button to advance the time. Joe
SOURCE: How do I replace the lights, radio controls on steering wheel.
there is no bulb you need to replace the switch in the steering wheel
SOURCE: The switches on my steering wheel that control
Look for a iluminated fuse,or inst.lps,fuse,try moving the dial,or knob to brighten the instrument lighting.
2stroke Jim suggested I disconnect battery for 10 minutes and then reconnect. It worked!!! Thank you
It worked for me too for my Buick Allure - Canadian equivalent of the Lacrosse.
