My dad recently changed the password to the new K9 Web Protection because he somehow figured out that I figured the other password out. The program is installed on my laptop and I do not know how to get rid of it. I have tried everything from randomly typing in a password to starting with safe mode. Nothing works and this program is pretty solid. I have also tried changing the license but I'm not so sure I've been doing it right. The program is set on High Protection so it won't even let me go on chat on my gmail. I would appreciate it SO much if someone helped me get rid of K9. Thank you.
It is so simple ... when your pc boots up ... if your not admin ... if ur on windows xp press F12 or F11 .. but i fink its F12 .. alot of times whilst it boots up .. and it will give you master reset choice .. do the fird option ... also .. if you have access to your dads email .. get k9 to send password 2 email .. then use the password .. simple as really? ... any question ask [email protected]
i will be happy to supply more help on this subject or more ...
This is the real only way ive found after hours of searching to get rid of this. First off you need to be the computer administrator with the k9 web protection on. You need to fallow these steps carefully
Also, Youll want to go to http://www1.k9webprotection.com/getk9/download-software.php Download the software and put it in under YOUR email and edit it so it unblocks everything :) if you guys have any questions or need me to explain a little more send me an email @ [email protected]
Thank you
I heard that you could press ctrl + alt + del and end the K9 Web Protection process. If that doesn't work, then you can install a key logger on your computer and on your parents computer. A key logger will keep track of every key that is pressed and ever mouse click. So, if you parents type in their password, then you will be able to see it. In addition, to keeping track of everything that is pressed, some key loggers will take a screen shot ever time a key is pressed or the mouse is clicked. The good thing about key loggers is that they are comletely discrete. There isn't an icon or program that a person could delete easily.
THIS THING IS SO F***** ANNOYIN! I CANT VISIT FACEBOOK, NOT EVEN MY EMAIL! SOMEONE TELL ME HOW TO REMOVE THIS THING! WITHOUT PASSWORD!
First you have to get administrator privileges (if you already do, Ignore this) but when starting up your computer get into recovery mode (Esc then F11, or whatever you have to do in the startup menu). If you have HP support on your computer, click the center panel and go into command prompt cmd prompt you cd to System32 folder on windows 7 (like C:\Windows\System32). you do that, then follow this order very carefully: copy cmd.exe cmd1.exe then rename sethc.exe sethc1.exe then rename cmd1.exe sethc.exe then get out of recovery mode, but typical people have NORMAL COMPUTERS. when you try to recover, hit cancel when asked about system restore. When the error message pops up, click on the details, open the text doc, and click save as. In that window, you browse to C:\Windows\System32 and basically do what you can do in the cmd prompt. copy cmd.exe, rename sethc.exe, then rename cmd.exe's copy to sethc.exe, then reboot normally. at the login screen, trigger sticky keys (hit shift many times) which brings up the command prompt. You can type explorer.exe in it to bring up SYSTEM's taskbar, which probably has internet explorer on it. That is the only browser that works on it. Warning: it may disappear randomly and make your computer slower. But SYSTEM has admin privs! do as you please. you are welcome
Do not lsten to this message if you do not have acess to your mom or dads email or whoever the k9 system sends a tempary password to!!!!!!!!!!to get a temperary password to k9 you go to the screen where it gives you three options, they say view internet activity, help, and setup. then you click on setup or internet activity and then it will probably bring up the screen that lets you put in the passcode. ehen you get there you can click on "forget password" and it will send a temperary password to your dad or moms email. you simply get into their email find the email with the tempary password the n put that in as password. you can then remove k9 from your computer or change the screw up the whole peice of **** k9 ****.
Useless
Well you can get Revo Uninstaller Pro it will get rid of it no hassles
Has anyone heard of CCleaner? It does have two C's. What you do is you go on the site, go to the Tools section, and then you will see a list of programs your computer or laptop has. You go to where it says K-( Security or something like that & go to Than you click on the button that says Delete Entry. There, your K-9 problems are over! Have fun!!
[email protected] i need a new passwor
There is indeed a much easier to do this guys, though i may not remember it too well, as i did it so long ago, but here it is based on how i remember it. Look up an older version of K9 online, try to find the oldest one possible, and download from a site like sourceforge that the newer one wouldn't block. As soon as you install it, i think it will overwrite the old one and you can re-configure the passwords and stuff. After leaving the 'new' old version on for awhile to trick my parents, i eventually just deleted all of K9, and gone it was.
I have figured it out. This solution does not involve uninstalling K9 or restoring you computer. If you are on windows, go to start and search (or run) for msconfig and run it. Go to services and uncheck K9 web protection. When it asks you to restart you computer, click restart. Once you have your computer running again, open your web browser. It will prompt you with a "cannot connect to K9 web service server" You will now only be able to connect to websites that support ssl (aka https) I found that the proxy website https://proximize.me/
works for almost any website you wish to visit, even if it doesent support ssl.
Happy surfing!
U know what u should do, 1st of all u have to know ur dads email that he installed k9 bluecoat protection with then go 2 any website that doesn't work because of k9 protection (myspace,face-book) then it will say allow this site.... then u click the arrow that says 15 minutes and click allow site permanently then it will ask u a choice by saying request site view your change your settings then click change your setting then it'll ask u the password then click forgot password then it'll ask u would u like a to have a temporary password sent to ur email then click yes then if u know ur fathers password that he installed the k9 with follow ur dad everytime if he's on the pc then he might check
if it dont work email m,e at [email protected]
Friends,
Problem with Dell Laptops?
For solutions for your problem you need to visit a site by just Click Here .
For any hardware problem with Dell Laptop you can Click Here
You can always ask a frind how to create a batch file that deletes the system drive, basically destroys your computer, then act very upset, say you were experimenting and that it was an accident then you get new laptop, if they put it on that one your SCREWED!
Have you tried going into safe mode and then doing a system restore? You don't lose any info but whatever programs are installed goes bye-bye. Whats your user status on this machine? Admin or user? Can you ctrl-alt-delete and kill the process? Hope this helped.
First you have to get administrator privileges (if you already do, Ignore this) but when starting up your computer get into recovery mode (Esc then F11, or whatever you have to do in the startup menu). If you have HP support on your computer, click the center panel and go into command prompt cmd prompt you cd to System32 folder on windows 7 (like C:\Windows\System32). you do that, then follow this order very carefully: copy cmd.exe cmd1.exe then rename sethc.exe sethc1.exe then rename cmd1.exe sethc.exe then get out of recovery mode, but typical people have NORMAL COMPUTERS. when you try to recover, hit cancel when asked about system restore. When the error message pops up, click on the details, open the text doc, and click save as. In that window, you browse to C:\Windows\System32 and basically do what you can do in the cmd prompt. copy cmd.exe, rename sethc.exe, then rename cmd.exe's copy to sethc.exe, then reboot normally. at the login screen, trigger sticky keys (hit shift many times) which brings up the command prompt. You can type explorer.exe in it to bring up SYSTEM's taskbar, which probably has internet explorer on it. That is the only browser that works on it. Warning: it may disappear randomly and make your computer slower. But SYSTEM has admin privs! do as you please. you are welcome. Also, you can delete anything (but you can't restore it from SYSTEM's recycle bin!).
Go search bckd.sys and delete it and restart computer when your done restore it from the recycle bin and every thing will be back to normal
PLEASE INSTALL A KEYLOGGER SOFTWARE AND FIND THE PASSWORD
These are the official uninstall instructions:
Please follow the instructions below to uninstall K9 Web Protection. Make sure you are connected to the internet before uninstalling K9 so your license can be released. If this is not possible, you can continue to uninstall, but you will need to request a new K9 license if you want to reinstall K9 in the future.
After rebooting, K9 will be completely uninstalled.
Solution
You can find many solutions over the net but dont try it else the internet will be blocked.. just ask for a new password and they will mail you... You need to click on forgot password.
rofl exactly the same but i havent found out the pass ever -.-
if you kill the process it also kills your internet and will not let you view ANYTHING. seems as though the internet runs through k9 when you have it installed, I too have it installed and I hate it.
i got the same peob i know how to get around it though all u gotta do is get ur parent email pass then u send the password 2 k9 to there email and wala
The k9 web protection has been bugging me for about three months now, I want to be able to get rid of it without my Dad knowing, but how can I when I don't the password? Please, help me get rid of this!
My dad installed k9 web protection. I wantt 2 get on youtube to record songs but my freakin dad installed k9. how do i get rid of it?
how to get their password
I need to delete k9 without an email or password!!!!!!!!!!!!!
i have a solution to your problem if you still need it
i need to get past k9 with no password or email but my mom and dad dont see it
Then type:
argh! silly comment windows! in the cmd prompt you cd to System32 folder on windows 7 (like C:\Windows\System32). you do that, then follow this order very carefully: copy cmd.exe cmd1.exe then rename sethc.exe sethc1.exe then rename cmd1.exe sethc.exe
