Hello everybody. So, not so long ago I bought ZoomH4 and was using it as well. I used not an original adapter,but I can managed voltage and all was okay. But one day, after 3-4 weeks not using my Zoom, I tried to record some stuff - and my wish was crushed. When I'm trying to switch it on using adapter, Zoom shows me menu for plugging into PC. And when I'm trying to plug it into PC I fail to do this. When I try yo switch it on using battery, Zomm just shows me "now boot loading", then his indicator blinks once and starts to repeat from the beginning: "now boot loading" blink "now boot loading" blink "now boot loading" ...
You are on the wrong website for this type of inquiry. This is a community based self-help website for the repair and use of manufactured products made for consumer use
Yes! it is very possible, specs are different in none original power adapters, because it sounds like the charging circuits are working. I recommend getting the original adapter for your model.
hello eustus... your best bet is to call your local lock smith and have him provide you with a couple of new keys and he will also be able to reset your password for you. Joe
Is the AC Power adapter the original adapter of the laptop? If it is,
try to drain the battery and charge it for 8-12 hours without using or opening the laptop just charge it. After charging, remove the power adapter as you open your laptop. Make this way a habbit of using and charging your laptop to make the charging and battery life last long.
Are you absolutely sure that you have the correct card/driver combination, make sure you have correct driver. Also install as Administrator, and run any software associated with it as Administrator, too.
Go to device manager, right click on adapter, and uninstall the adapter, reboot, then, when it boots up, again, it should "Ask" for drivers, show it were the driver files are. OR don't continue with autoinstall, cancel, and run the install software to do so as said above.
I was reading lots of forums and tech support pages on how to get my Cricut back online. I went to the store and got the Deep Cutting Blade & Housing and I got two replacement blades for the original housing that came with the Cricut. I also bought a pack of new mats. I replaced the original blade with a new one, used a new mat, and tweaked the depth and speed of my cuts and my little Cricut is whirling again!
