Question about HP LaserJet Office Equipment & Supplies
"Ready 2 download" on Laser Jet Pro 300 Color MFP
  • HP Master
  • 1,915 Answers
There is a utility and special firmware used to fix this problem. You will need to contact HP Tech Support as the 300 series is not listed in the downloads I have access to.
Posted on Dec 03, 2016
4 Suggested Answers
  • 1479 Answers
SOURCE: How do i copy a
you could look at these, the first tells you how to do it manually and you can download the manual from the second
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c01916001&jumpid=reg_R1002_USEN
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?lang=en&cc=us&taskId=101&contentType=SupportManual&docIndexId=64255&prodSeriesId=3597338&prodTypeId=18972
Posted on Apr 01, 2011
SOURCE: download driver for Window 7 the HP Laser Jet M1522nf MFP
go to folowing link you will get drivers for windows7
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=3442754&lang=en&cc=us&prodTypeId=18972&prodSeriesId=3442750&taskId=135
Posted on May 04, 2010
  • 123 Answers
SOURCE: HP laser jet 1522nf mfp ( firm ware corrupt ready 2 download)
Perform the following troubleshooting in the order listed:
  1. Turn off the printer, with the communication cable still attached.
  2. Clear the print spooler by doing the following:
    1. Go to Start then choose Run .
    2. Type net stop spooler , and press Enter .
    3. The Windows XP spool directory is located at: C:\WINDOWS\SYSTEM32\SPOOL\PRINTER ; Delete every file within this folder.
    4. Go to Start , then Run , and type net start spooler , and press Enter .
  3. Manually delete and reinstall the driver:
  4. To uninstall printer driver, refer to the following steps:
    1. Open Printers folder and right click the driver that you wish to delete.
    2. Within the menu, select Remove .
    3. For the confirmation message displayed, click Yes .
    4. Right click the Printer Folder and select Server Property .
    5. Click Drivers tab, and select the driver for deletion. Click Remove .
    6. For the confirmation message for the deletion, click Yes .
  5. Install the printer driver manually as follows:
    1. Select the Printers and Faxes option from the Start menu.
    2. Click "Add a printer" then, on the resulting "Add Printer Wizard" dialog, click Next.
    3. Ensure the option "Local printer attached to this computer" is selected. Untick the checkbox "Automatically detect and install my Plug and Play printer". Click Next.
    4. Ensure that the option "Use the following port:" is selected then select the appropriate port from the drop-down choice box. When choosing port, use one of Virtual Printer Ports for USB to which is your printer connected to. Click Next.
    5. Click the "Have Disk..." button. On the "Install From Disk" dialog, click Browse... then navigate to the appropriate directory to which the software/driver extracted.
    6. Select an inf file then click the "Open" button. Click OK on the "Install From Disk" dialog.
    The Add Printer Wizard will start to copy driver files to the PC.
  6. Run the firmware upgrade with the printer turned off so that the printer accepts the firmware only after the entire file is spooled.
  7. In the firmware update program's window, choose your printer (manually installed) and press Send Firmware button, and wait for the firmware to be spooled completely.
  8. Power-on the printer.
  9. During the printer firmware update, the liquid crystal display (LCD) on the printer control panel will display Printing Document and will change to Erasing . After a short while, the LCD display will change to Programming . After a short while, the LCD will display complete The Ready LED on the printer will start flashing. The printer will automatically power off and then back on to reboot, and will make noises similar to that of a power-on operation.
Posted on Jul 14, 2010
My laser jet pro map m177fw is stuck initializing, and i have tried everything. i have read several other's issues, but mine persists. can you help?
Please review the HP troubleshooting for your printer:
HP Color LaserJet Pro MFP M177fw
If this printer is new, you may need to make sure the toner cartridges are seated and installed correctly.
It appears others have had similar issues and solutions are provided here:
Laserjet Pro MFP M177FW stuck in Initializing
May 16, 2017 | The Office Equipment & Supplies
Problem hp pro 300 don't copy black
Check your black cartidge even if it's new. Take it to a refill site,
they may unstuck it using utrasound
Oct 24, 2015 | HP LaserJet Pro 300 Color MFP M375NW...
Hp laser jet 300/400 10.1000error
10.10 error means it does not recognize the chip on the cartridge or that the seal is still in cartridge need new cartridge
Feb 24, 2015 | HP LaserJet Pro 400 color M451dn - Printer...
Supply error
make sure you have removed an orange small plastic piece if u don't remove printer will detect it as a Supply memory error
hp laserjet pro m1213nf mfp driver Software downloads Hp Drivers
Apr 01, 2014 | HP LaserJet Pro 400 color M451dn - Printer...
I need the pdl_common disc
not required for any disc.....you need to download latest drivers for win xp from hp web site if you need download link pls send me one request mail to me...satyan476@gmail.com
Mar 21, 2014 | Hewlett Packard Printing & Imaging Hewlett...
I have an error code 58.04 on my hp color laser jet pro 300 M351a can you help me out to reslove this error
Lots of suggestions from the HP site: http://h30499.www3.hp.com/t5/Multifunction-and-All-in-One/HP-Color-LaserJet-CM6040-MFP-58-04-Error-message-error-code-not/td-p/4821025#.VVCSS5I4nTY
Jan 28, 2014 | Office Equipment & Supplies
USBPRINT\HEWLETT-PACKARDHP_LASERJET_CM1415FN\8&A98C29E&0&USB001 i have hp laser jet pro cm1415fn color mfp printer i need driver pls
Unplug the USB cable
Load the CD or download the full-solutions from HP.
Only plug in the USB cable when told
Sep 30, 2013 | National Geographic Cameras
355 people viewed this question
Clive
Clive
