Yes it can be replaced. If you go to www.ereplacementparts.com, you can look up your sander and find the parts you need. You can buy the parts there or get the part numbers and search the web for pricing.
The belt platen elevation mechanism cannot be set properly.
200 S03 Transfer belt motor timeout The motor shaft encoder of the transfer belt motor does not attain the specified pulse count within the specified time. The required movement does not complete even when the transfer belt motor operates for the specified interval. 201 S03 Transfer belt unit sensor error The three sensors that determine the position of the belt platen produced an abnormal detection result. 231 S03 Belt platen operation error The upper limit position sensor fails to activate when the belt platen rises. 240 S03 Belt platen operation error The upper limit position sensor fails to deactivate when the belt platen lowers. 241 S03 Belt platen operation error The lower limit position sensor fails to activate when the belt platen lowers. 242 S03 Belt platen operation error The lower limit position sensor fails to deactivate when the belt platen rises. 243 S03 Belt platen operation error The vacuum positioning sensor fails to activate when the belt platen operates. 244 S03 Belt platen operation error The vacuum positioning sensor fails to deactivate when the belt platen operates.
Remedy:<>Reset power, or execute [Clear error] in Test mode. <>Some errors (such as PCB disconnection) may not be cleared by executing [Clear error]. <>Even if an S error occurs, it may be possible to continue operations using another unit. Therefore, certain error types require a specific reset procedure (described in Error Point).
Take it in for service, or replace all the sensors if you can find them for sale.
Are you referring to the platen roller? The platen roller is the cylinder that's underneath the printhead which pulls the labels from the roll/box and then pushes it at a certain speed so that the printhead prints onto the label. The platen roller is usually coated in rubber and you can check if the platen roller has some eroded or cut sections.
Unfortunately, the platen roller is a consumable item, you'll need to replace the platen roller. Take a look at our blog for more information about the platen roller.
The answer "Go to Dewaltservicenet" can be confusing - the actual site is servicenet.dewalt.com and even then, entering your part to get to manual can be infuriating. This is the link for the current model which, for all intents and purposes, is the same. The link to the helpful page is: http://www.dewalt.com/tools/woodworking-sanders-orbital-sanders-d26441k.aspx . You'll get a pop-up box with a dropdown that has a few numbers, nothing else. Just click on "1" and ignore language that indicates that this model has more than one - it does not. After you click on "1", the pop-up disappears that you're on the d/l page. Downloads are in the upper right corner. You want "Instruction Manual".You should get to this page: http://servicenet.dewalt.com/Parts/Browse#6229 but may not, it's very glitchy. On this page, you'll want to make sure "Sanders" is on the left and "sheet" is on the right. If you try to get the Manual from the DW411 page, a blank page will open. Make sure your pop-up blocker is off or that you allow dewalt.com. The instructions for the d26441k are identical to the dw411 - same technique for loading sanding sheets, same rods, etc. I've uploaded the d26441k page manual .pdf so that should help. It's easy to get lost on the Dewalt site while trying to find somthing so simple. :)
If the right platen latch is broken it can easily be replaced to lock down the platen. If the left one is damaged then you have to replace the entire platen as that is much more difficult to repair.
if your platen calibration is not done. 1 Resat All Platen Connection of cabal 2 Replace Logic Card 3 Check Platen Moving proper 4 Than Check Sensor And Platen Aliment 5 Than replace Platen Sensor 6 Please Check Platen Motor Regards yogendra Sharma
go to Dewaltservicenet.com and in the midle of the page and towards the bottom under need manual type in your model number and you should be able to download anbreakdown and operators manual
best way is go to dewaltservicenet.com and they have a service/repair center locator section type in your information and you can find one pretty close that way. Also you can download a schematic for the tool while you are there.
I dont think that you are missing anything, but you might want to go to Dewaltservicenet.com and download a breakdown for this tool. it might be that the platen is stuck and needs some "gentle" persuassion to remove.
