I have a Sprint EVO 4G LTE that will receive a WiFi signal but will not connect unless I am within a couple feet of the router if I'm lucky. I downloaded the WiFi analyzer app and the phone is receiving the signal at normal levels. I have another of the exact model which is not experiencing this problem at all.
SOURCE: i forgot the device pattern for my sprint htc evo
If you keep entering the wrong pattern eventually it will ask you to sign into your google account and then you will be able to choose another pattern.
SOURCE: how to connect jawbone bluetooth device to htc evo
HOW TO CONNECT BLUETOOTH
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
SOURCE: my sprint 4g evo wont
Go to Menu-> Settings-> update then update prl and profile. Reboot device if problem continues Go to Sprint
SOURCE: how to connect sprint htc evo 4g on boost mobile
Sorry but you cannot connect it to boast mobile. That phone is a sprint exclusive phone.
I hope this helps. If you need more help just reply.
SOURCE: Can i use HTC EVO 4G Smartphone on Reliance CDMA
Yes, It can be "unlocked" and you can make it work on Reliance CDMA network. I just got my phone unlocked and using it on Reliance Network. Go with a reputed dealer who could unlock it; don't try doing it by yourself. I got it done from a guy who was located in Delhi via remote access.
