Curves in the road are a common occurrence and cars are easily equipped to go around them.
The wire could be off a number of things, but you can test by turning all the lights on, especially the low level fog lights. Also try the horn, as if I remember correctly it is located above the passenger wheel arch liner.
its not a bad job on a neon ,the fog light kit you will buy will come
with a switch and the relay and wiring for installing them,they also
came with a real good set of directions for doing this,if you need to
get someone to help you with doing this,sometimes running the wires is
tricky,but other than that the fog lights can be mounted in the same
place as the originals was,and they look good,i sold my 97 neon and i
had fog lights on it,they were after market but looked and worked
excellent,with a little work and time anyone can install a set on any
car,good luck.
you can take loose the black plastic shield that runs from inner fender to bottom of bumper. once loose you gain access to back of fog light where mounting bolts are located if its just the bulb your replacing you can also do that without removing it
if you look directly under the bumper just under the fog light you will see a bracket that holds a 13 mm bolt. undo that and pop the light out from the front of the bumper and replace the bulb. install is the reverse
