SOURCE: Mintek TV and Direct TV remote wont program
Try a code search, the method should be in the manual. If you can't get that to work then it's not possible to use the DirecTV remote.
If that's the case then get a learning remote.
SOURCE: Infrared sensor won't work in a Toshiba TV
The remote wouldn't work on my brand new 46" Toshiba TV. Comcast person said the tv gave off an infrared signal that interferred with the Comcast remote.
Solution was to turn on cable box FIRST, then TV ( now I use All On button, which turns on cable first). If I turn on TV first, the remote wouldn't work consistently. Hope this works for you.
Testimonial: "Thank you for your response. I tried the steps you suggested and it worked! Thanks for the help! "
SOURCE: TV says no signal from direct tv box
Yes, something could have gotten changed.
Confirm what input connection the DirecTV receiver is connected to on the back of the TV. Using the remote, check that the TV has that input selected.
SOURCE: hi, i resently bought a toshiba regza 42
I have the same problem. You need a new audio/video board.
Here is how mine sounds:
http://www.youtube.com/watch?v=yAXqWIhQYa4
Thanks for your response. Turns out its a problem with the cable provider. they are working on a fix so hopefully the prolem will go away.
