SOURCE: Lenovo Y410 Touchpad has stopped working
These devices are generally quite reliable so I would be looking for the possibililty of a damaged software driver.
If the touchpad is completely dead, use the tab and arrow keys to access the Control Panel.
Open the Mouse folder, go to the Hardware tab, locate the touchpad entry (it is likely shown as a mouse), highlight it and delete the entry.
Exit the open windows, reboot your computer.
If the touch pad is functional at all, Windows should show a dialog box stating 'Found new hardware' and it may also say that it is installing the software for it.
It may however, ask you to insert a disk with the software on it and that would be on any recovery disk that came with your notebook.
If it does not see the touchpad because it is defective, then it is a failure of the touchpad.
Good luck-
SOURCE: lenovo 3000 Y410 speaker does not work
Try going into device manager
click start
then control panel
then system
they hardware
then device manager
if there is a yellow !mark next to sound then use the properties tab to reinstall the the driver
Hope this helps
SOURCE: cost of display ic for Lenovo 3000 Y410 Laptop
If you haven't fixed it yet. The best price I can do is $82.00.
