I tried all the diff methods to make the called ID work..
my normal phone shows the caller ID but this cordless phone from UNIDEN just doesnt show up the number..
how to set caller ID uniden n32 phonehow to set caller ID uniden n32 phone
AnonymousMar 20, 2014
displayed time on the caller ID doesn't work properly. It is always behind normal time. I reset it several times but it didn't work. can it be repaired or I need to buy a new main phone. Phone model DITECH 6.0 d1688displayed time on the caller ID doesn't work properly. It is always behind normal time. I reset it several times but it didn't work. can it be repaired or I need to buy a new main phone. Phone model DITECH 6.0 d1688
AnonymousMar 24, 2014
Caller ID service from telco is on; worked beautifully with previous phone system, but with this Uniden, it only records the phone number of caller about 1 our of 10 time. Most other entries are blank. Haven't been able to find any means of making this work properly.Caller ID service from telco is on; worked beautifully with previous phone system, but with this Uniden, it only records the phone number of caller about 1 our of 10 time. Most other entries are blank. Haven't been able to find any means of making this work properly.
AnonymousMar 25, 2014
My caller id on my cordless phone has stopped working. I can scroll through the ID's and names are there, but when the phone rings it says unknown caller.My caller id on my cordless phone has stopped working. I can scroll through the ID's and names are there, but when the phone rings it says unknown caller.
You can't post conmments that contain an email address.
Using the Caller ID and Redial Lists Caller ID (CID) is a service available from your telephone provider that shows the phone number (and sometimes the caller's name) of incoming calls. Contact your telephone provider for more information. Caller ID list
Redial list
When a call comes in, the phone displays the number and name (if available) of the caller.
The phone saves the information for the last 30 received calls to the
CID list.
When it's in standby, the handset shows how many calls came in since the last time you checked the CID list.
Each handset remembers the last 5 numbers you dialed on it. The redial list is separate for each handset.
Negative, the SX 50 does not support CID. You can upgrade the Mitel or use a CID Multi line interface to a PC. Here is one such model. http://www.callerid.com/
If you go to the bottom of the page on the right, click on how it works. Hope this hlpes.
Hi! There is a small device available in the market which is a converter. By connecting this between landline and phone, caller ID start display simply.
It cost to me Rs.450/- made by Fintel. Try to get it cheaper at your place.
Some phones are not equiped to pick up call waiting caller id. check the box or look up your model number on the uniden site. The call waiting caller id only shows up on the phone that is in use at the time of the call.
Make sure that you have caller id service from your phone company. If you do not have a different phone with caller id borrow a working one from a friend and see if it shows up on a different phone. Let a phone ring at least twice to give caller id time to work. If a different phone does not show the call information call your service provider.
I was using this site while trouble shooting this in the US...
If the customer has DSL with filters in the same system go back to the NID and Isolate the DSL,
test the caller id and call waiting caller id. If this works you have Data Bleed coming from the DSL.
Make sure there are not two sets of filters on the line. Tjis customer had a filter with the DSL modem.
Doing this we just fixed an on going problem for a field tech who was the second callout on a customer issue.
