We recently changed our tv and now the volume and off button won't work on the sky remote. Is it possible to change a setting of some sort to make it work again. The tv is made by 'mirai' thanks!
ie menu = Menu
Channel up/down = take you up and down
volume = goes left and right.
follow these steps
Menu,
channel down button to CHANNEL
press the volume button along
channel down button to AUTO STORE
press the volume button to Start the scan.
right now you have your telly tuned in. What you could do it get an old sky remote off a friend/ neighbour. or buy from argos etc ( a lot cheaper then getting a replacement samsung one)
press the following buttons on the sky remote to program it to work with your samsung tv.
TV,
RED + SELECT
TV.
0060
try the volume if this works press SELECT to save this code if it doesnt press Tv then try the volume again. repeat this step until the volume works your telly. once it doest dont forget to press the SELECT button to save.
Now you will be able to change your volume use the number keys. if you also press the HELP button on the sky remote this will also change your AV / SOURCE I hope this post helps you out. When it does please leave a thumbs up for me Please
Please follow the steps below with the sky remote:
TV
RED + SELECT
TV
0053
press the volume button if this works press the SELECT button to save if not press TV then volume again. repeat this step until the volume works. Dont forget to press the SELECT button to save the code.
Please follow the steps below with you Sky remote.
TV,
RED + SELECT (flashes twice)
TV
0056
Try the volume button if this works then press the SELECT button on the remote. If not press the TV button and try the volume again. repeat this step until the volume works the tv then remember to press the SELECT button to save the code to the remote.
If for any reason this does not work then what I would like you to do is take the battery cover off the remote. You will see a label on there stating what REV 4,6,8 it is. The numbers indicate how old the sky remote is. If your LG telly is a newer tv then you may need to purchase a newer Rev sky remote.
The above should sort you out no Problem Kenny
first of all I would like you to press the blue sky button on the top of your remote. Now press you tv guide button. If this has sorted it Great if not read on!!
what I am going to talk you through now is resetting your remote:
TV
999
now press the blue sky button at the top of your remote now try the tv guide button. this should work no problem now.
now to the small matter of tuning your remote back in to work your volume etc
please follow the steps below:
TV
RED + SELECT
TV
0056
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
please follow the steps below with you sky remote:
TV
RED + SELECT (hold these down until it flashes twice)
TV
0056
Try the volume button if this works then press SELECT. If it does not work then press TV again then try the volume ( repeat this step until the volume works. Dont forget to press the SELECT button to save the code to the remote.
This should sort you out. Please leave a thumbs up when you get it working.
Right you said in your post that it only works part of the tv, what this is when you have saved the code into the remote it is very close but not the correct code for the LG Model you have. So imput the code as mentioned above but when your checking the volume dont press SELECT straight away try the help button. power button etc then save that code if it works them.
when it is the correct code you should be able to press the TV button then power = power . Help = changes av / source. Number button change channels etc. On certain tv's on a sky + or hd the pause/play changes the aspect ration on the tv aswell.
When this sorts you out please leave a thumbs up
cheers
press and hold select and red until the led blinks twice type in 0 0 6 0 press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
