SMC Barricade g SMCWBR14T-G Wireless Router (SMCWBR14TG) Logo
Posted on Jan 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
WLAN does not work
Hello there.. i was told that if my wireless is working the WLAN lights will blink, but mine doesnt.. it was working properly yesterday, but when i turned on my laptop again, no connection from my router can be found.. i tried to connect to network but my laptop can't find the router.. im using windows vista.. the LAN, and WAN lights are blinking.. but the WLAN lights doesn't.. what should i do? please help :(
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 310 Answers
  • Posted on Jun 16, 2009
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
310
Questions
Helped
88454
Points
729
Can you try and reset the router once. I guess that should help . There should be a reset button behind the router and the reset procedure should be present in the manual
1 Related Answer
Anonymous
  • 61 Answers
  • Posted on Mar 15, 2009
SOURCE: Laptop can't see my network
It does sound like you may need to upgrade firmware. Not sure what router you have but you can download firmware & install from the router's website.
You might like to try:
1. Disable Windows Firewall
2. In Internet Options Control Panel go to the connection tab and then the LAN Settings where you can uncheck the "Automatically detect settings" button.
3. If you have any third party software, I would get rid of this and ensure that the"Windows Zero Configuration" in the Services menu is set to "Automatic" and the status is started.
Interestingly, Anti Virus programs sometimes interfere with wireless set up - you could see if it helps by disabling it whilst configuring your wireless. It might also be worth trying to connect without any encryption code & see if that will connect - you can then sort out the encryption.
2answers
Smc 802.11g adapter doesnt show in wlan utility
update the wireless drivers for your network card. also check the spec sheet for your wireless card and make sure it's compatable with your OS and system.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_d799f810c7212a78
1helpful
2answers
Status and WLAN lights only blink
DI-624 is a bit old and mine has failed from overheating on occasion. Check that it is not in direct sunlight. If it is hot to the touch, see if it works after cooling off a bit. I had a client who had no problems for five months, until spring. One day his wifi crapped out every time the sun came out and it took me forever to figure that one out.
Should the status light be blinking?
you should call the wireless manager.
good luck.
My linksys wrt160n wireless router light is blinking
Welcome to FixYa
Indication of Router Lights:
  • Power light blinks. If LAN or WAN cable is plugged in, their respective lights will flash on activity.
  • Power light turns off for several seconds.
  • All lights, except power light, turn on and then off.
  • Power light blinks slowly, then faster, and WLAN light will turn on.
  • Once Power light and WLAN light are on solid, the router is fully rebooted.
A working router should show solid green power light. upgrade the firmware of the router.
If this Helped you-Rate me..Thanks for Using FixYa
TEW-432BRP Wireless Router (TEW432BRP): i was playing on my laptop when the routers wirele...
seems like it got stuck in service mode; you should try to rewrite/update firmware (as provided by the manufacturer's site)
Hi, I have a dlink DSL-G604T router, wlan light not on.
Hello there!
Only thing that can cause your wlan light not working consistantly or with some blinks (which is normal thing) is bad lan cable which leads from your ADSL modem to your wlan entrance on your wireless router, please check that cable in order to fix that problem. Cable doesnt need to be coaxial so it can have 2 different lan sets (2 poles of exits male and female exit). Thats it ! =)
Please rate solution! =)
Sincerely
Aleksandar Adzic
3helpful
2answers
My wlan light keep going on and off on my wrt54g
Also check if the power light on your router is blinking. If it is blinking, that's an indication of hardware failure. To revive it, do a hard reset. Press and hold the power button of the router for 30 seconds then unplug the power. Wait for 30 seconds again before you plug it back in.
Wireless-G Broadband Router
The WLAN light will normally blink if there is data passing through. Most often if the problem is that you need a reboot for the router to work again you will need to update the firmware of your router. You need to go to www.linksys.com then click on the top right search then look for your model number then select the option to WRT54G downloads. Search for your model and then download the firmware. After that on a computer wired to your router go to http://192.168.1.1 through Internet Explorer. Click on the administration tab then click Choose. Select the file that you downloaded then click on Upgrade. That should fix your problem.
2answers
Router not being recongized
if your running windows xp then you should remove any programs that you installed to run router then look into hardware manager and uninstall router and restart computer . then try once again plug in router once comp boots and let win xp load the correct drivers if this doesnt work go to windows update website and get all available updates including all hardware updated then try installing again good luck with it
Top SMC Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
